Steel Alloys Materials
8 posts • Page 1 of 1
delle
Post by delle » Fri Nov 06, 2009 9:42 pm
Hi guys, today I'll do some tests onto different types of Steel Alloys.
This is the first Material: "Stainless Steel 18/10".
I've created it using this composition: 18% Cr.nk + 10% Ni.nk + 72% Fesi2epi.nk
Here is some Wikipedia Info on this Steel:
A typical composition of 18% chromium and 10% nickel, commonly known as 18/10 stainless, is often used in flatware. Similarly, 18/0 and 18/8 are also available.
NOTE: Rendering in progress... :wink:
Stainless Steel 18-10.JPG (29.82 KiB) Viewed 4658 times
psor
Re: Steel Alloys Materials
Post by psor » Fri Nov 06, 2009 9:56 pm
Hey delle,
I'd like to ask you for a favor. While you're at it, could you please check if it is slower to blend
NK files instead using specular reflectivity or single self made NK file. Thanks! ;o))
take care
psor
"The sleeper must awaken"
delle
Post by delle » Fri Nov 06, 2009 10:08 pm
psor wrote:.... or single self made NK file....
I've tryied to use the Tinman's Software in the past to create new NK files but it behave in a stange way (maybe it has a bug but Tinman disappeared from the Web :( ) and I prefer to blend measured NK file than trying to create a new one... :roll:
..specially in the IOR values, I get "sinusoids" :shock:
Here is what I get if I read a real NK file and then what I get if I try to feke it... :? :roll:
Fake NK File
Fake NK File.PNG (21.65 KiB) Viewed 4663 times
Real NK File
Real NK File.PNG (21 KiB) Viewed 4663 times
Jambert
Post by Jambert » Fri Nov 06, 2009 11:42 pm
Realy nice material :)
Please upload :wink:
delle
Post by delle » Sat Nov 07, 2009 12:08 am
Jambert wrote:Realy nice material :)
Done :wink:
Jambert
Post by Jambert » Sat Nov 07, 2009 12:46 am
Done :wink:
thx :)
delle
Post by delle » Sat Nov 07, 2009 2:06 am
New Steel Alloy: 40% Fesi2epi.nk + 42% Ni.nk + 38% Fesi2el2.nk.nk
This Steel with high percentage of Nickel is a little bit clearer than the old one and can be used to create Sink etc... :wink:
Stainless Steel with high Nickel.png (371.54 KiB) Viewed 4572 times
delle
Post by delle » Sat Nov 07, 2009 3:23 am
New Steel Alloy: 40% Fesi2epi.nk + 42% Cr.nk + 38% Fesi2el2.nk.nk
This Steel with high percentage of Chrome, can be used to create Faucets etc... :wink:
Stainless Steel with high Chrome.png.png (349.7 KiB) Viewed 4551 times
