dichroic glass
dichroic glass
I'm modeling a new building we are designing. Modeling in Blender and going to da final render with Indigo.
It's supposed to have a glass skin treated with a dichroic thin film or coating.
I though maybe indigo would be able to render this kind of material somehow, but I don't really know how. could someone help me pointing me in the right direction?
What was the magic of the procedural texture hva ? Based on light or camera angles, or world orientation ? These informations are not accessible via isl (apart maybe the later), they must be taken ("baked" ?) from the host app/exporter to be aknowledged by the Indigo Shading Language; this is an advanced topic, exporter-specific until isl allow such accesses.
Questions regarding your scene:
Do you expect transparency from your dichroic glass ? If yes, how close/accurate ? Or reflections would be enough ?
The most accurate approximation I can imagine right now is a glass with different colors for absorbtion and sub-surface scattering. Scatter should be of a tight spread angle... Either what you might be able to bake the procedural texture and use it on a blended phong, as specular_reflectivity...
all theorical
all theorical
Something around those lines:
Don't use that material if it's not for real glassery or jewelry, not that it correspond to an existing material but it will not be efficient for exterior shots I fear.
Again it's an approximation, colours are split not based on their wavelenghts but on their nature, absorbed/scattered. Though, the phase_function parameter will dispatch scattering based on wavelenghts (kind of), you may want to experiment with that one. Also you may want to divide scale-dependent parameters by 10 or 100 in that code. Finally, colors are not balanced.
An image with that material is cooking, will post.
<medium>
<name>dichrolike_medium</name>
<precedence>6</precedence>
<basic>
<ior>1.393849969</ior>
<rgb>
<rgb>0.0420953331 0.010 0.03045000076</rgb>
<gamma>2.200000048</gamma>
</rgb>
<subsurface_scattering>
<rgb>
<rgb>3.195000076 16 4.097499847</rgb>
</rgb>
<phase_function>
<henyey_greenstein>
<g_spectrum>
<rgb>
<rgb>1 0 1</rgb>
<gamma>1</gamma>
</rgb>
</g_spectrum>
</henyey_greenstein>
</phase_function>
</subsurface_scattering>
</basic>
</medium>
<material>
<name>previewmaterial</name>
<specular>
<internal_medium_name>dicrolike_medium</internal_medium_name>
</specular>
</material>Again it's an approximation, colours are split not based on their wavelenghts but on their nature, absorbed/scattered. Though, the phase_function parameter will dispatch scattering based on wavelenghts (kind of), you may want to experiment with that one. Also you may want to divide scale-dependent parameters by 10 or 100 in that code. Finally, colors are not balanced.
Eat it crude then
(edit: it's better cooked now)
You can see the effect of the phase function: scattering red and blue components are propagating almost straight inside the medium, while green has a razing scattering angle. Of course both emiters are of plain white emission.
Edit: directly inspired by http://www.indigorenderer.com/joomla/co ... temId=6578
PS: Unlike what I formerly stated, since this shader heavily relies on phase function it can be called "polychroic" (can it actually ?), dichroism is effectively reached because R and B components have the same phase param; It's not simply discriminating between (non) absorbed light and scattered light.
- dichrolike.jpg (29.4 KiB) Viewed 15973 times
I'm currently tweaking the material, depending on results I may upload it in the matDB.
Update:
Nearly final, you can save it as an igm file.
Update:
<scenedata>
<medium>
<name>dichro_medium</name>
<basic>
<rgb>
<rgb>6 3.5 3</rgb>
<gamma>2.2</gamma>
</rgb>
<rgb>
<rgb>11 6 14</rgb>
</rgb>
<phase_function>
<henyey_greenstein>
<g_spectrum>
<peak>
<peak_min>485</peak_min>
<peak_width>80</peak_width>
<base_value>-0.065</base_value>
<peak_value>0.72</peak_value>
</peak>
</g_spectrum>
</phase_function>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>dichro_medium</internal_medium_name>
</specular>
</material>
</scenedata>- Attachments
- Interesting one for optical coating, settings were lost amongst multiple tests ;(
- dichroic2.jpg (56.57 KiB) Viewed 15966 times
- actual material
- dichroic.jpg (58.5 KiB) Viewed 15969 times
Some investigations:
from http://www.lasercommunity.com/lc_view_p ... php?aid=17 about lasers:
found this: J-band Dichroic Mirror Transmission Data Table - [link to main page]
Note that the page also contains interesting atmospherical data.
wich pointed me to perhaps use tabulated data for phase function, along with another one for ior [edit: scratch the later]...If you really want a beamsplitter, they are available online. Watch out, as some are polarizing (reflect/refract based on the angle of polarization of the laser) while others are dichroic (reflect/refract based on wavelength of light).
Final, or close; I'm not sure about absorbtion:
Some more tweakings and I upload it.
<scenedata>
<medium>
<name>dichroic_glass_A_medium</name>
<basic>
<ior>1.39</ior>
<cauchy_b_coeff>0.0018</cauchy_b_coeff>
<rgb>
<rgb>1.27 2.45 1.8</rgb>
<gamma>2.2</gamma>
</rgb>
<rgb>
<rgb>4.4 3.2 4.8</rgb>
</rgb>
<phase_function>
<henyey_greenstein>
<g_spectrum>
<!--peak>
<peak_min>480</peak_min>
<peak_width>70</peak_width>
</peak-->
<regular_tabulated>
<start_wavelength>0.4E-06</start_wavelength>
<end_wavelength>0.7E-06</end_wavelength>
<num_values>6</num_values>
<values>
-0.975 -0.8 -0.6 0.6 0.8 0.975
</values>
</regular_tabulated>
</g_spectrum>
</phase_function>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>dichroic_glass_A_medium</internal_medium_name>
</specular>
</material>
- ior changed to 1.72, panes are about 8mm of thickness
- dichroic_building.jpg (56.83 KiB) Viewed 15916 times
- soft dichroic glass
- dichroic_glass_A.jpg (42.42 KiB) Viewed 15921 times
- PureSpider
If that wasn't with you I would have beaten my own record right now
Eeew, I'm tweaking, documenting myself, rendering, pruning renders, learning, eventually spreading knowledge...
Basically reporting, no
Note: All these materials should greatly benefit from a very subtle bump mapping, smooth wavy style. If you can displace that, that would be even better. Perfect flat surfaces are so boring !
Removed dichroic_glass_E cause it had wrong settings (negative absorbtion).
Would you help render Pure
edit; more references for dichroic glasses: http://www.worldglassnet.com/pages/appG ... subcat=All
PostS.: I edited previous codes, they weren't matching the matDB naming convention, I think that's better now. Will do a last check before upload.
<scenedata>
<medium>
<name>dichroic_glass_B_medium</name>
<basic>
<ior>1.48357</ior>
<cauchy_b_coeff>0.00072487</cauchy_b_coeff>
<regular_tabulated>
<start_wavelength>0.4E-06</start_wavelength> <!-- from the beginning of the visible spectrum -->
<end_wavelength>0.7E-06</end_wavelength> <!-- to its end -->
<num_values>20</num_values> <!-- get 20 samples -->
<values> <!-- 5x4 -->
0 0.01 0.03 0.003 0.0186127
0.006 0.008 0.1 0.095 0
0.8639 0.81 0.07983 0.62 0.541978
0.94 0.007439 0.24 0.000612 0.00624
</values>
<regular_tabulated>
<num_values>10</num_values>
<values>
0.2 0.94 0.81 0.62 0 0.1 0.006 0.003 0.01 0
</values>
<phase_function>
<henyey_greenstein>
<g_spectrum>
<regular_tabulated>
<values>
0.027 -0.25 -0.975 -0.8 -0.96 0.62 0.81 0.094 0.18 0.05
</values>
</g_spectrum>
</phase_function>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>dichroic_glass_B_medium</internal_medium_name>
</specular>
</material>
</scenedata>Code: Select all
<scenedata>
<medium>
<name>dichroic_glass_D_medium</name>
<basic>
<ior>1.72</ior>
<rgb>
<gamma>2.2</gamma>
</rgb>
<regular_tabulated>
<values>
0 -0.25 -0.975 -0.8 -0.6 0.62 0.81 0.94 0.2 0
</values>
<phase_function>
<henyey_greenstein>
<g_spectrum>
<regular_tabulated>
<values>
</values>
</g_spectrum>
</phase_function>
</basic>
</medium>
<material>
<specular>
<internal_medium_name>dichroic_glass_D_medium</internal_medium_name>
</specular>
</material>
</scenedata>Would you help render Pure
- dichroic_glass_B_building.jpg (60.07 KiB) Viewed 15816 times
- closer to usual dichroic arch glass I guess
- dichroic_glass_B.jpg (42.74 KiB) Viewed 15816 times
- cool strange things happening
- dichroic_glass_D_building.jpg (58.82 KiB) Viewed 15878 times
- A characterized one
- dichroic_glass_D.jpg (44.65 KiB) Viewed 15877 times
