Making Realistic Carpet
Re: Making Realistic Carpet
Wow. That is really nice.
- zeitmeister
Very nice!
Getting close to photorealism!
..I was actually re-thinking about it: how do you scatter the component over sloping terrain Dale? I mean, your dummy is a string or similar, I suppose: that way, the furred instances would be directioned towards the normal of the base surface. Is that right?Whaat wrote:..using the fur plugin (actually, the Make Crowd tool), I can easily scatter my 'dummy grass' components across sloping terrain.
With the make crowd feature, you have the option for the component to Stand Up or point in the direction of the surface normal.Pibuz wrote:..I was actually re-thinking about it: how do you scatter the component over sloping terrain Dale? I mean, your dummy is a string or similar, I suppose: that way, the furred instances would be directioned towards the normal of the base surface. Is that right?Whaat wrote:..using the fur plugin (actually, the Make Crowd tool), I can easily scatter my 'dummy grass' components across sloping terrain.
great! Thanks!
