Some of you may already know it, but for those who don't, I want to introduce you to my plugin Layers Panel.
http://sketchucation.com/plugin/751-layers_panel
The main reason I'm posting it here is for its render feature that can be very usefull for people doing rendrings inside Sketchup. Here is a short video (Made with Vray but it works the same with Indigo)
http://www.youtube.com/watch?v=o62le_MUUZQ
Let me know what you think, and if you have ideas for other features.
Layers Panel
Re: Layers Panel
This plugin is really smart! Thank you!
I haven't tested it yet (BUT I WILL), but may I ask a question?
One of the problems I encountered using layers is that objects which are put in a hidden layer cannot work as referencies for other objects, while simple hidden objects can. Working with Indigo, this is typically the case of dummies:if the complex tree is on a hidden layer the geometry isn't exported so your dummy doesn't get the reference and cannot be substituted; if the complex tree is simply hidden, the dummy works as it would.
Does your plugin allow this kind of trick?
Thank you!
Thank you!
jiminy-billy-bob
Re: Layers Panel
It should, yes. A layer with its teapot active is sent to the renderer. Is that what you're looking for?
- fenerolina
Re: Layers Panel
Will certainly have a look, very welcome plugin! thank you billy bob.
