Should work, too.buzzkill wrote:How about RT?Pibuz wrote:Indigo now does!
Wishlist
Re: Wishlist
Re: Wishlist
Would be nice to be able to change the halt time or SPP after rendering has begun.
Jeff Hammond
Re: Wishlist
maybe a material override option? (for clay renders of already textured model)
basically, click a button and all the materials will export as a single user defined material.
also. a ground plane option would be nice (not sure if this is could be done via skindigo alone?)
(not original ideas.. stole them from maxwell's sketchup plugin)
Re: Wishlist
Hi Jeff,Jeff Hammond wrote:maybe a material override option? (for clay renders of already textured model)
You can change to monochrome face mode to make clay renders. The clay material will be the same color as your default front face material. However, this mode does not offer any further customization.
I have often thought it would be nice to have a ground plane option but since it only takes 5 seconds to create a ground plane in SketchUp, I have never bothered. (maybe someday)
Jeff Hammond
Re: Wishlist
ha.. never tried monochrome prior to exporting. I just assumed the materials would go along with it regardless of viewing mode..
re: ground plane.. yeah. it's easy to draw a square on the ground but sometimes I'd like the plane to extend to the horizon.. I always find myself drawing a huge square at Z=0 but I still have to use a higher than desired pov in order to not show the edges of the ground (which in turn eliminates the option for sky)
I'm not sure if indigo would have to render the infinite plane or not? I guess if it did, the feature would be useless
Re: Wishlist
Hi Whaat! Something silly which you'll be able to implement in no time: in the render settings window, output panel, you should make the "image name" string grey until the "custom image name" check is validated: this way it would be clear how the command works.
Sorry for the request: I'm facing some students in these days, and that is good to see their responses to some not-too-explicit settings I'm actually used to..
- Antonis777
Re: Wishlist
Single surface subsurface scattering materials (s5)...! Along with sss more user friendly. (That's only because I don't understand the glossy transperant feature)!
Re: Wishlist
Single surface SSS (Diffuse Transmitter type) is created by having a Diffuse or Phong material with SketchUp opacity less than 100.Antonis777 wrote:Single surface subsurface scattering materials (s5)...! Along with sss more user friendly. (That's only because I don't understand the glossy transperant feature)!
The material will be exported as a Blend between the orginal material (Diffuse or Phong) and a diffuse transmitter material using the opacity value as the blend factor.
For example, if you create a Diffuse material with opacity set to 25%, you will get a Blend material that is 25% Diffuse and 75% Diffuse Transmitter
This is explained in the SkIndigo tutorials:
http://www.indigorenderer.com/sketchup
Tutorials are currently being updated BTW.
- Antonis777
Re: Wishlist
Thanks a lot! It's clear to me now.
Re: Wishlist
Hi Whaat!
I come out with this dream of mine: a few days ago I saw C4D integration with Indigo Renderer, and thought that would be WONDERFUL TO HAVE in SkIndigo too! ..maybe I am shooting a little too high (as we say in Italy
..I would also like to bump the mat test scene request: between the available mat test scenes, I think nobody uses cube or sphere or monkey anymore! I'd very like to have a testscene in METERS so the real bump/displacement value is applied to the previewed material too..
..and some time ago dcm posted very good mat test scenes which I'd very like to see included as optional test scenes in SKIndigo
Tell me if I can help in any way!
Re: Wishlist
It is a dream of mine too but I currently don't have the knowledge to do this. As you can imagine, this would take a LOT of development time, and I would rather spend this time working on features such as ....Pibuz wrote:Hi Whaat!
I come out with this dream of mine: a few days ago I saw C4D integration with Indigo Renderer, and thought that would be WONDERFUL TO HAVE in SkIndigo too! ..maybe I am shooting a little too high (as we say in Italy) ?
You'll be pleased to know that reworking of material previews is number one on my priority list for the next version of SkIndigo. First up...preview scene in METERS...I would also like to bump the mat test scene request: between the available mat test scenes, I think nobody uses cube or sphere or monkey anymore! I'd very like to have a testscene in METERS so the real bump/displacement value is applied to the previewed material too..
..and some time ago dcm posted very good mat test scenes which I'd very like to see included as optional test scenes in SKIndigo![]()
Thanks
Re: Wishlist
sorry for bumping it A LOT!
Re: Wishlist
Hi Whaat,
Is there any chance the 'Apply Settings to Scene' button could come back?
I noticed in this thread - http://www.indigorenderer.com/forum/vie ... 17&t=10871 - that it was temporarily removed due to bugs.
It was a really handy button, especially when you have a large model with multiple scenes, inside and outside - I'm missing it from v2!
Thanks,
Jen
Thanks,
Jen
Architect in training...
...almost done!
...almost done!
Re: Wishlist
Hi Jen,gjengi wrote:Hi Whaat,
Thanks,
Jen
Sorry but it's not likely likely that it will be back. While it was very handy, it also could be confusing, especially for new users. I was having a lot of headaches with it. Weird bugs and issues.
Re: Wishlist
No worries Whaat, thought I'd just check, I can understand if it causes more problems than it solves!Whaat wrote:Hi Jen,gjengi wrote:Hi Whaat,
Thanks,
Jen
...almost done!
...almost done!
Users browsing this forum: No registered users and 122 guests
