Please feel free to make modification to this code and also please post source modifications here, so we can make this exporter support all Indigo features.
Below I attached trueSpace7.11 RsScn file with example how to use this exporter.
Note:
1. IMEBank obj is bank of Indigo Material Editor. You must put all material inside this IMEBank. Also you must put this IMEBank on scene root.
2. To paint an object with above material, you need "IndigoMaterialName" obj inside the object you want to paint. Indigo Default material is use if you dont put this 'IndigoMaterialName" obj inside the object. (at Link Editor, look inside plane obj for reference).
3. You also must put Expoter itseft on scene root.
Hope above note can help you on how to use this exporter.
Enjoy!
