7- Upon request
7- Upon request
7- Upon request: browse to the Indigo application to locate it.
Hello,
sorry how can I locate the indigo app? where? in maya?
thanks!!
Hello,
thanks!!
Re: 7- Upon request
You need to install Indigo to launch it via Exporter!
Grab the latest installer from here: http://www.indigorenderer.com/forum/vie ... =1&t=12403
Re: 7- Upon request
but I have already indigo installed..Zom-B wrote:You need to install Indigo to launch it via Exporter!
when I click on render, at first appered an alert that say to me to set the folder of indigo I think, but I have ignored it clicking on "next time" and now when I try to make a render appear the error...
Re: 7- Upon request
There should normally be a MtI menu upright in the main Maya menu; its third menu item starting from below is "Rendere Path...".
From there, browse to the indigo application forlder then press ok - there is no file to select just browse into the Indigo Installation dir.
Rendering should be possible then.
Re: 7- Upon request
ah ok, now I have done.CTZn wrote:There should normally be a MtI menu upright in the main Maya menu; its third menu item starting from below is "Rendere Path...".
I selected the indigo folder but.......maya still send me the error
Re: 7- Upon request
Here the official tutorial: http://www.indigorenderer.com/documenta ... stallation
Re: 7- Upon request
Thanks Zom-B. Well, there's no troubleshooting shipped either...
ashadow, enter the following MEL code in order to check that the renderer path has been correctly set up:
Thanks for posting the error if it is persisting (please check the Script Editor then).
I'll be AFK the next 4 days.
optionVar -q indigoRendererPathI'll be AFK the next 4 days.
Re: 7- Upon request
When I instal indigo it say to me "3ds max" not, maya, is this ok?CTZn wrote:Thanks Zom-B. Well, there's no troubleshooting shipped either...
Thanks for posting the error if it is persisting (please check the Script Editor then).Code: Select all
the error is: Impossible to find the file indigo
and sometimes: "Error, can you ?"
Re: 7- Upon request
NO!!!ashadow wrote:When I instal indigo it say to me "3ds max" not, maya, is this ok?
ehm.... what??!ashadow wrote:the error is: Impossible to find the file indigo
Use THIS Exporter: http://www.indigorenderer.com/forum/vie ... 11&t=12157
And follow THAT instruction: http://www.indigorenderer.com/documenta ... stallation
The 3dMax Exporter is NOT for Maya!
Re: 7- Upon request
keep calm.Zom-B wrote:NO!!!ashadow wrote:When I instal indigo it say to me "3ds max" not, maya, is this ok?ehm.... what??!ashadow wrote:the error is: Impossible to find the file indigo
was only the wrong exporter, don't know why, I followed the link before.
thanks now works
Re: 7- Upon request
I have updated the getting started section of the Maya Exporter download page, sorry about the previous edition wich I found quite rude retrospectively.
Thank you for the heads up ashadow.
Heck people just take on the scripts.
