area light
7 posts • Page 1 of 1
ollle
area light
Post by ollle » Wed Oct 18, 2006 4:25 am
Hi!
I tried to make an area light (created an area light in C4D), but it wasn't imported in the xml-file. Is there a trick? I gave the light in C4D a indigo-light-tag. But it didn't work. Is there a special trick or bug?
manitwo
Post by manitwo » Wed Oct 18, 2006 4:32 am
You have to use meshlights. :wink:
Take a plane, make it editable and use this as lightsource.(as you will
see the normal direction is important :P )
No other possibility yet (afaik).
ollle
Post by ollle » Wed Oct 18, 2006 4:37 am
manitwo wrote:You have to use meshlights. :wink:
This means, the plane needs the indigo-light-tag? The position and direction is then taken from the plane?
manitwo
Post by manitwo » Wed Oct 18, 2006 4:49 am
yes :wink:
ollle
Post by ollle » Wed Oct 18, 2006 5:03 am
manitwo wrote:yes :wink:
OK, thanks! Seems to work. Can i switch off the sunlight? That only the meshlight illuminates the scene?
Not sure about that....
manitwo
Post by manitwo » Wed Oct 18, 2006 5:16 am
To remove the sunlight simply remove the sun-nullobject in the
rendersetting-tag. To remove the background light i think you have to
remove the <background>....</background> element in the xml by hand.
ollle
Post by ollle » Wed Oct 18, 2006 5:27 am
manitwo wrote:To remove the sunlight simply remove the sun-nullobject in the
Hmmm, when i remove the null-object (as default, this field is empty) and i start indigo, theres an error about the lack of "radiance".
For the background, i set the color to 0,2,0 (near black)....
