Problems with export
14 posts • Page 1 of 1
bparhitektura
Post by bparhitektura » Tue Jan 05, 2016 4:25 am
Hello,
I have problems with exporting from cinema to indigo. When I try to export there is allways info box which in saying, that it is imposible to export file. I have some experience with rendering in cinema+indigo, but now I newlly instaled it again after comp crush and it doesn't work anymore.
I also can not render inside of cinema with indigo engine....
If anyone knows why, I would be grateful to know. Please helpp me :roll:
Greetings
BP
bparhitektura
Re: Problems with export
Post by bparhitektura » Fri Jan 15, 2016 1:15 am
Hello,
Now I installed Indigo for sketchup, and I tried to work there, but program gives me an answer, that i dont have the right directory fil in my computer. I added screen shot of this troube in sketch and cinema. I need it to finish my school renders for master degree. I know how to work with this program, but probbably I don't know how to instal it right. I would be grateful, if anyone can help me.
SreckoM
Post by SreckoM » Sat Jan 16, 2016 11:17 pm
Do not use extended latin letters for your account name. Indigo can not resolve your path obviously.
bparhitektura
Post by bparhitektura » Fri Jan 22, 2016 10:39 pm
I rebooted my computer and I named all files without Slovenian letters, but anyway it doesn't work. Now it answer me, that cindigo plugin cause problems. I'm little bit nervous because of it. It seems to be no help for my problem. One year ago I made really nice renders with Indigo trial version, but now it is hopeless.
Post by Zom-B » Fri Jan 22, 2016 11:44 pm
Hey bparhitektura,
please upload the bugreport from the path that C4D gives you.
In that folder should be a "_BugReport.zip".
bparhitektura
Post by bparhitektura » Sat Jan 23, 2016 12:20 am
erased
bparhitektura
Post by bparhitektura » Sat Jan 23, 2016 12:22 am
erased
bparhitektura
Post by bparhitektura » Sat Jan 23, 2016 12:23 am
erased
Post by Zom-B » Sat Jan 23, 2016 12:57 am
It looks like you are using the release version of C4D R13.
There has been quite some updates from Maxon since then, think about upgrading your 13.016 to 13.061:
http://www.maxon.net/support/updates/cinema-4d-r13.html
Maybe this already helps regarding your crashes, since Developers can't keep compatibility to old unpatched versions of exporters!
You also only posted the content of that TXT file and not the whole ZIP as I requested :)
bparhitektura
Post by bparhitektura » Sat Jan 23, 2016 3:09 am
Hi, sorry for that. Now I have it all.
:D
_BugReport.zip
(17.07 KiB) Downloaded 305 times
bparhitektura
Post by bparhitektura » Sat Jan 23, 2016 6:23 am
HELLO HELLO :D
You are genious :) I just needed to update it and now i'm able to countinue with my work. Thank you very much.
I'' dind,'t know that updates are so important.
Have a nice evening!
Greetings
Bozidar
bparhitektura
Post by bparhitektura » Sun Feb 07, 2016 10:57 pm
again me.... sorry for that :)
I have new problem. Maybe that means that I need to update cinema again or is this kind of modeling trouble.
Post by Zom-B » Mon Feb 08, 2016 7:11 pm
Hey bparhitektura,
you cut of the explanation of that error in the box, please paste the full error report here :)
bparhitektura
Post by bparhitektura » Tue Feb 09, 2016 2:17 am
this is another half of report. There is problem with data structures.
Zajeta slika.PNG (6.89 KiB) Viewed 12358 times
