problem rendering to displacement
Hi all,
I have a concern about an object that I modeled in zbrush and then export to C4D (r12) with maps of displacement and normal maps. I tried to convert the material and then to launch a report on indigo, but it does not work. No detail is not apparent. How can I fix it and what type of setting should I do? thank you in advance for your help.
I will put you in copying the model of screen captures in zbrush, and rendered via cinema4d (AR3)
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Zbrush 4
Re: problem rendering to displacement
here's what I get when I run a report on the setting here indigo.t matter in C4D.
Thank you for your help.
Zbrush 4
Zbrush 4
Hey Schmums,
first of all check your export scene scale to be correct, you'll find it under the environment tab in the Indigo renderer settings.
If you export your Dragon as 200m big, a 2.5cm displacement will not be visible
Next you need to subdiv your basemesh! Do so by using C4Ds Hypernurbs or Indigos subdiv modifier by right-clicking on the mesh in the object tree > Cindigo Tags > Indigo subdivision Tag.
Using Indigo subdiv modifier disable phong angle breaks (unchecking on top box of C4Ds Phong Tag)
I hope that helps
I hope that helps
Thank you s much!
It's very clear i'm try it
Zbrush 4
Zbrush 4
Hello, I followed the steps that you indicated to me. However I have a recurring error message that prevents me enough to run a report (see the error message). And impossible to see where it comes from I'm looking in the settings of indigo c4d. I can not find or it's coming
Zbrush 4
Zbrush 4
Hi SCHMUMS,
which version of Cindigo and which version of Indigo are you using? They need to match (for Cindigo 3.2.1, for example, you should at least use Indigo 3.2.1 or newer, not older).
Regards,
Yves
Regards,
Yves
If you encounter errors or bugs, first thing to do always, is to use the latest version of exporter & Indigo:
Indigo 3.2.9: http://www.indigorenderer.com/forum/vie ... =1&t=11481
Cindigo 3.2.9.1: http://www.indigorenderer.com/forum/vie ... 10&t=11491
Regarding your scene setup:
- the dragon needs a C4D phong Tag as described in my previous post!
- the subdiv tag needs to ckeck smoothing, to smoth the mesh like a C4D Hypernurb would do
- play with viewdependet settings for some saving in triangle count and RAM usage in Indigo
(Not suported if your mesh is in quads, then it gets ignored!)
Ah yes ... actually last night I downloaded version 3.2.9.1 of cindigo (osx) and did not do the update INDIGO which remained in 3.0.10 ...
Zom-B sorry I had understood the need to disable the phong tag ...
Sorry for bad English (I'm french guy)
Zbrush 4
Zbrush 4
disabling the checkbox only, so no angle limitation happens.SCHMUMS wrote:Zom-B sorry I had understood the need to disable the phong tag ...
No problem mateSCHMUMS wrote:Sorry for bad English (I'm french guy)
I think I did as you had indicated to me previously. I metsz all my settings as the result it gives me something very inflated ...
Zbrush 4
Zbrush 4
for the phong tag disable the "Angle maximum" checkbox, that I was referring to previously. because by that on angles higher then 80° Indigos displacement disconnects polygons and causes black holes in your mesh!
Your displacement map is center based with RGB 128 grey collor a zero point. to use such displacement & bump maps you need to lower the c value to half of b value.
In your settings it would be:
a: 0
b: 0.6
c: -0.3
a: 0
b: 0.6
c: -0.3
AC seems to work!
Thank you for your help and patience
Zbrush 4
Zbrush 4
Be so nice and reward my effort with a renderingSCHMUMS wrote:AC seems to work!
And last question, is that I can combine (as in c4d) of my displacement map and normal map? If so in what channel is what I have to put
Zbrush 4
Zbrush 4
There no support for normal maps in Indigo, the question was asked 3 days ago: http://www.indigorenderer.com/forum/vie ... 14#p114014SCHMUMS wrote:And last question, is that I can combine (as in c4d) of my displacement map and normal map?
You will probably find a related topic into the Bugs and Requests subforum if you want to add your voice in.
