Sayris
by Sayris » Sat Jul 05, 2008 5:09 am
Hi fused, I really appreciate your hard work to help us
If I try to render some older szenes in Indigo it crashes everytime with the error:
"IndigoDriverExcep:SceneLoaderExcep:ModelLoadingStreamHandleExcep: Normal does not have lenght 1. (In element 'mesh', around line 2, column5)"
I think Zom-b should have told you already (and send a file?).
cheers.
edit: nevermind, it does work with the new version
Camox
by fused » Sat Jul 05, 2008 6:39 am
nice...
did you edited the igs?
Onfame
by Onfame » Sat Jul 05, 2008 7:04 am
Hey Fused, i think i found a bug, everytime when i start Indigo and try to render a "*.igs" File, Indigo crashes with following:
IndigoDriverExcep: SceneLoaderExcep: IndigoModelParser2Excep: Unexpected element 'used_material_name'.(In element 'mesh', around line 2, column 5)
Edit1.: And how is DOF now working without the "Sensor Widht"? I tried everything but i could not get any Depth into my Pics
Can anyone tell me exactly how it works now?
by Borgleader » Sat Jul 05, 2008 8:11 am
Camox. that stone displacement is awesome. Great job. Give it to me?
by fused » Sat Jul 05, 2008 8:24 am
Onfame wrote:Hey Fused, i think i found a bug, everytime when i start Indigo and try to render a "*.igs" File, Indigo crashes with following:
Hey Onfame! are you sure you are using
Indigo 1.1.5?
sensor width is still there. cindigo exports the value from the c4d camera.
to see some dof:
-make sure you set the global scale multiplier right
-lower f-stop if you still dont see any
Camox
by Camox » Sat Jul 05, 2008 10:10 am
fused wrote:nice...
No ,all material tag settings. The exporter is great, thanks over again!
Borgleader wrote:Camox. that stone displacement is awesome. Great job. Give it to me?
Hi Borgleader,it is very simple, easy in the material tag following settings:
Phong
ior:1.3
exponent:50
bumpmap
0.001
displacementmap
exponent: 1
0.2
thats all,i hope it is understandable.
The textures you get here.
http://mxmgallery.maxwellrender.com/sea ... earch=disp
by pixie » Sat Jul 05, 2008 11:52 am
fused wrote:Hey Onfame! are you sure you are using
Indigo 1.1.5?
to see some dof:
And it's working nicely and easy!
- test
- im1215205056.png (227.08 KiB) Viewed 6529 times
by fused » Sat Jul 05, 2008 11:46 pm
Camox wrote:fused wrote:nice...
no, imeant if you editedt the preview scene -> displacement/subdiv at the base
Onfame
by Onfame » Sun Jul 06, 2008 12:21 am
Yes i used Indigo 1.1.5 but it is not working, i tried multiple Values for the Global Scale Multiplier but that didn´t affect indigo at all also i tried most of the f-stop values
- Dof in Cinema
- c4dtest.jpg (31.99 KiB) Viewed 6486 times
- the same scene in Indigo
- indigo.jpg (67.93 KiB) Viewed 6487 times
Marcofly
by Marcofly » Sun Jul 06, 2008 1:37 am
great!!!!!
keep on with your wonderful work!
ciao, see you soon!
marco
by Kram1032 » Sun Jul 06, 2008 8:28 am
Onfame, use the lowest possible f-stop value aswell as a very low world scale factor (like 0.01 or so) then, DoF should be perfectly visible
Camox
by Camox » Sun Jul 06, 2008 10:00 pm
Ups, no i have not used the cindigo preview scene.
Onfame
by Onfame » Sun Jul 06, 2008 11:19 pm
Kram1032 wrote:Onfame, use the lowest possible f-stop value aswell as a very low world scale factor (like 0.01 or so) then, DoF should be perfectly visible
I know everything you said but since cindigo 1.1.5b it doesn´t seem to work on my pc anymore
- A testrender in indigo woth the settings from c4d
- testdof.JPG (45.47 KiB) Viewed 6377 times
by pixie » Sun Jul 06, 2008 11:37 pm
I use Global scale at 0.001 what is the size of the balls?
pixie on Mon Jul 07, 2008 3:41 am, edited 1 time in total.
