Cindigo 1.1.9 Beta
- pixie
@Fused:
Strang since the light uses it, I thought it would be a matter of using the same template wherever it is used. It's not as I use it, I was just curious to check how would it run, I even got my wikipedia ready to do the test, the thing is since Indigo uses and it is part of the real world measures it would be best to be in then out.
Now, since we're on requests:
1. Set run indigo default on and priority below normal
2. On materials preview, cancel is the default state whereas preview should be the prefered one since that's what the user is there after all, if user mistakes then he can at any time close the shell window whereas otherwise it has to re do it all again.
