Cindigo 1.0.6 (updated 8th Feb 2008)
Post by pixie » Fri Jan 25, 2008 9:33 am
Cindigo now gives me this error... any idea?
Error
studiomoccoro
Post by studiomoccoro » Fri Jan 25, 2008 9:37 am
ZomB wrote:Hi dude...
It seems you are using the latest stable Indigo version 0.9.10.
The Cindigo exporter is named by the version of Indigo it is compatible to,
tnx ZomB. that did it.
Post by pixie » Fri Jan 25, 2008 9:48 am
pixie wrote:Cindigo now gives me this error... any idea?
Optimizing the object seems to solve the problem...
Post by fused » Fri Jan 25, 2008 9:52 am
kind of. this might be caused by unused points or degenerate polygons. try "optimize" on this model (with polygons, unused points and points).
edit: so you found it out by yourself :)
Post by Zom-B » Fri Jan 25, 2008 1:51 pm
Yes... see point l) on this post
Post by fused » Mon Jan 28, 2008 10:10 pm
ZomB wrote:Bugs:
3) Primitives tagged with the light tag get exported using default_mat.
4) instancing of primitives doesn't work.
8 ) Oh... width & height are get exported visa versa ^^
Some Ideas:
c) it would be great, if Instances of complex multi structured objects like Chairs, or car tires with (lot of) childes could be supported.
d) Different Materials for Instances should be possible... Maybe here some kind of Random color checkbox for materials could be nice, maybe an interesting feature for scenes heavily using instances... maybe...
n) Cindigo & C4D both asks if the existing files should be overwritten, if exporting.
p) On the saving dialog, the file extension should be limited to .igs as default, and xml as a second file option.
Hey!
i had a little time lately and your request c) is ready for testing.
some comments on the rest:
3) where is the problem with that?
4) is working now.
8 ) which? can you pealse explain it a bit further?
d) i said it before... it would be a nice feature, but i dont think its worth the effort
n) has a reason and i wont change it. ever. (the reason is, that in some cases cinema doesnt ask you)
p) is currently impossible.
testrender of the new instance export:
mrmoose
Post by mrmoose » Mon Jan 28, 2008 11:39 pm
Wow, hierarchy instances export is a great feature!!! Great work fused!!!
I'd like to see rectangle light and the other indigo primitives (sphere, plane) implementation too :wink:
mrmoose :D
psor
Post by psor » Mon Jan 28, 2008 11:43 pm
Excellent work fused! 8) :D ;)
@mrmoose
I really like your little gallery a lot dude! :D :D ;)
take care
psor
"The sleeper must awaken"
Post by fused » Mon Jan 28, 2008 11:43 pm
mrmoose wrote:Wow, hierarchy instances export is a great feature!!! Great work fused!!!
I'd like to see rectangle light implementation too :wink:
mrmoose :D
thank you.
to avoid misunderstandings:
hierarchy instances export is not a feature of the current exporter. it will be in the next version/update.
Post by Zom-B » Tue Jan 29, 2008 5:45 am
Hey fused, looks great this new instances export :D
For me the last main missed feature, now Cindigo is getting rock solid for me!
About your questions:
3) The problem is, that the Light Tag on Spheres are ignored... they don't emit any light, but get exported as simple diffuse material objects using the default_mat.
8 ) The width & height settings in the Camera Object are mixed up. if I set the picture to have a 100px width & 500px height, its exported to e height of 100px, and is 500px width
I'll update the list according to your response, and delete the requests that aren't possible etc.
And again: Thanks for your great work dude!
mrmoose
Post by mrmoose » Tue Jan 29, 2008 10:36 pm
psor wrote:@mrmoose
Thank you :wink:
Post by pixie » Wed Jan 30, 2008 7:04 am
I got this error again... and I optimize and yet to no avail :S
Marcofly
Post by Marcofly » Wed Jan 30, 2008 7:25 am
please upload the scene, or just the .obj element that gives you the error, so we can have a look at it..
Ciao!
Post by Zom-B » Wed Jan 30, 2008 8:07 am
pixie wrote:I got this error again... and I optimize and yet to no avail :S
For me on every scenario where this problems pops up, optimize with all 3 checkboxes checked and a tolerance of 0.00000001 worked fine...
Otherwise please upload your scene (snipped) so we can take a look just as Marco asked for...
Post by pixie » Wed Jan 30, 2008 10:11 am
Presto! :)
test.rar
test scene
(871.41 KiB) Downloaded 430 times
Locked
