Indigo 2.2.5, with Mat Editor beta 4
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_2.2.5_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.2.5_Setup.exe
Changelog:
2.2.5:
* Mat Editor: Changed spacing between widgets, changed style a bit.
* Mat Editor: Added 'Tools|Show Material File' command.
* Mat Editor: Download Materials are now downloaded to %APPDATA%/Indigo Renderer/downloaded_materials.
* Mat Editor: Added dockable, resizable widgets for material and parameter widgets.
* Mat Editor: Transferring some settings when changing between material types.
* Mat Editor: Added scrollable list of past preview renderings.
* Main GUI and Mat Editor: Mouse wheel now zooms in and out, left-click and drag scrolls image.
Changelog:
2.2.5:
Re: Indigo 2.2.5, with Mat Editor beta 4
Thanks ono :)
I have one request, it may be there but i have not found it :P
Being able to change tracing/render method ;)
- Doug Armand
Like the new GUI extras.
Its fun at first detaching/moving those panels :-)
Love the zoom ability and the on-screen display saying what zoom% your at.
Becoming a very, very useful tool :-)
Nice update. Installed and seems to run fine - no problems yet.
I haven't checked out the renderer as your list doesn't say there are any changes to it.
thanks, looks better and better...
- pixie
OMG I was to praise for a history system, and about to kill to! :D
Thank you Ono for the update.
Thanks! ;)
Thanks for the update!
+1 to thisStromberg wrote:Being able to change tracing/render method ;)
Thank you Ono!
drag doesn't work when render is full sizedOnoSendai wrote:* Main GUI and Mat Editor: Mouse wheel now zooms in and out, left-click and drag scrolls image.
edit: It's possible to drag render by zooming ;)
- Capture2.PNG (212.41 KiB) Viewed 18727 times
- Capture.PNG (933.46 KiB) Viewed 18745 times
The widgets are really nice.. :)
Also, what happened to the emoticons?
EDIT : The buttons look a bit too big when you dock the material list pane on the top.. They're a bit too long..
Also, something I thought of at work today...
The aspect ratio would remain constant.. Dragging would increase it in increments of 10 or whatever people agree on is a good number. :)
- turn the lights off carry home.jpg (80.13 KiB) Viewed 18379 times
First impressions are very good for the updated material editor. Functionality has been greatly improved. I like the system of setting absorption. Can you share how you calculate the coefficients from the distance setting?
(It would still be nice to be able to set the coefficients directly as an option)
Nice job overall!
Nice job overall!
a couple bugs found so far:
- you are still allowing the user to select shader or texture for base emission
- I undocked and closed the 'material/media' window and can't get it back
Hi Whaat,Whaat wrote:a couple bugs found so far:
1) Yes, but at least it doesn't crash now
2) That's fixed for new version
