Indigo 0.6 test 3
Indigo 0.6 test 3
Post by OnoSendai » Sun Oct 08, 2006 10:09 pm
Working towards the final 0.6 release.. here's test 3
Please post about any bugs found.
This should be a fully functioning release, as opposed to 0.6 test2.
http://www.indigorenderer.com/montecarl ... _test3.zip
Changelog:
* don't alloc and free buffer on tonemapping
* fixed broken stuff from 0.6 test2
* path tracing mode resurrected and is now progressive - can be run forever.
* sky_gain disabled for now
* other stuff probably
* fixed halt_time not working
zuegs
Post by zuegs » Sun Oct 08, 2006 10:39 pm
nice to hear from you Nick :D and thanks a lot for new release !
One small question, do you have a formula or link about relation of blackbody-temp and energie?
regards zuegs
eagle
probable bug?
Post by eagle » Sun Oct 08, 2006 11:06 pm
thanks for a new release with fixed stuff !
please check if program creates tree_cache directory , I've just tried with first xml I've found and seen lot of messages like "Failed to open file 'tree_cache/1510505112.tre' for writing." , when I created directory manualy and restarted , it created caches in it .... (I am working on local disk with admin rights so I guess that it should work)
Post by OnoSendai » Sun Oct 08, 2006 11:14 pm
Thanks eagle, I've uploaded a new version with an empty tree_cache dir.
zuegs
Post by zuegs » Sun Oct 08, 2006 11:20 pm
I've got much more white noise with v6t3 than v6t2 or v5 :?: :oops: will try other scenes and settings...
arneoog
Post by arneoog » Sun Oct 08, 2006 11:25 pm
Super Awsome! :D
I'm Going To Render My Scenes SO HARD! 8) :D :twisted:
Post by OnoSendai » Sun Oct 08, 2006 11:26 pm
zuegs wrote:I've got much more white noise with v6t3 than v6t2 or v5 :?: :oops: will try other scenes and settings...
Hmm.. what kind of mats?
Might have busted the importance sampling
arneoog
Post by arneoog » Sun Oct 08, 2006 11:28 pm
I get quite abit of white noise too...
On all kinds of materials :?
EDIT: There is most white noise when I use BlackBody Mesh Light, it seems...
EDIT2: I get it with RGB Mesh Light too...
Haven't tried Sunlight or Rectangle Light
zuegs
Post by zuegs » Sun Oct 08, 2006 11:34 pm
I'm using much phong and some diffuse... when i compare v6t2 and v6t3 i see quite more contrast in v6t3 (gamma?) and a lot of white dots on my gray diffuse wall... (btw exr output still clamped at <=1.0)
I go to try some simpler scene first befor... :oops: :oops:
Post by OnoSendai » Sun Oct 08, 2006 11:35 pm
Can u post an example comparison, with the 0.6 test 1 render as well?
Post by OnoSendai » Sun Oct 08, 2006 11:38 pm
zuegs wrote:(btw exr output still clamped at <=1.0)
tonemapped or untonemapped exr?
Post by OnoSendai » Sun Oct 08, 2006 11:41 pm
Oh yeah.. there is some burn-out now in the Reinhard tone mapping, which gives more contrast.
This will be a configurable parameter next release.
manitwo
Post by manitwo » Sun Oct 08, 2006 11:44 pm
we have a shutdown function ? ... :D :D thank you - top work!
it is also much faster isn't it? at the moment i can test it only on the computer of a friend of mine.
zuegs
Post by zuegs » Mon Oct 09, 2006 12:00 am
tonemapped exr with linear or reinhard seams to clamp, untonemapped exr still very small 14kB (when tonemapped is 2000kB)
Post by OnoSendai » Mon Oct 09, 2006 12:02 am
Well, tonemapping clamps as part of the process, so that's desired behaviour.
