Indigo Renderer 3.6.20 Beta Release
10 posts • Page 1 of 1
Post by fused » Tue Aug 27, 2013 4:38 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.20_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.20_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.20.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.20.tar.gz
Indigo for Mac OSX (10.6 - 10.8 ):
IndigoRenderer3.6.20.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.20_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.20_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.20.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.20.tar.gz
Indigo RT for Mac OSX (10.6 - 10.8 ):
IndigoRT3.6.20.dmg
Changelog:
3.6.20
* Resurrected the pack/unpack tool menu commands to get around problem of PIGS being extracted in temp dir when opened directly.
* Made scene/mat packing save ZIP files that play nice with 7-zip etc.. when it comes to path names with Unicode characters.
* Made scene/mat packing and unpacking have a progress bar UI that doesn't lock up the GUI.
* Fixed removing of alpha channel for shadow pass
* Fixed GUI hanging when stopping the render/closing the scene while transferring large buffers during network rendering.
* Fixed crash with foreground alpha, bidir + participating media.
* Increased default image save period to 30 mins.
* Fixed a bug where a scene with GPU use loaded on a computer without a GPU blocks the render mode from being changed.
* Fixed permissions issues on OSX.
* Fixed UI for volume parameters (e.g. medium absorption) not displaying and storing shader parameters.
* Fixed issue where network rendering could lock up the GUI on some scenes with many instances referring to large meshes.
* Fixed issues with loading interlaced PNGs causing 'Invalid chunk type' errors.
Re: Indigo Renderer 3.6.20 Beta Release
Post by pixie » Fri Aug 30, 2013 9:14 am
In PT MLT an invisible light ceases to be. Works on Bidir MLT and Bidir PT
ENSLAVER
Post by ENSLAVER » Tue Sep 03, 2013 6:11 pm
I get an "indigo.exe has stopped working" crash when I try to save an image file from an IGI that has no scene attached.
Open .IGI
Try to save image
Crash
If I resume the scene using the same IGI and try to save the image it works fine. I'm not sure if the windows dump files are of any use, attached anyway.
crashdump.7z
(1.13 MiB) Downloaded 357 times
Post by OnoSendai » Wed Sep 04, 2013 4:08 am
ENSLAVER: Fixed for next release.
Post by OnoSendai » Wed Sep 04, 2013 5:07 am
pixie wrote:In PT MLT an invisible light ceases to be. Works on Bidir MLT and Bidir PT
Can you send us a simple packed scene showing this problem?
Post by Zom-B » Wed Sep 04, 2013 5:56 am
I can confirm that invisible LightSources only work in BiDir modes!
Post by OnoSendai » Wed Sep 04, 2013 5:58 am
Send a scene, works fine here.
Post by Zom-B » Wed Sep 04, 2013 6:15 am
here you go:
BlackEmitter.pigs
(6.62 KiB) Downloaded 368 times
Post by OnoSendai » Wed Sep 04, 2013 9:58 am
Zom-B wrote:here you go:
Thanks for test scene. The issue was only showing up when light albedo was zero. Have fixed for next release.
Post by pixie » Wed Sep 04, 2013 7:36 pm
Naughty fused, naughty naughty! xD
