Indigo 2.2.12
Indigo 2.2.12
Post by OnoSendai » Fri Jan 08, 2010 11:30 am
This is a release candidate for 2.2 stable.
Please give this release a thorough test!
Builds for Mac and Linux will follow soon.
Indigo for Windows 32-bit:
IndigoRenderer_2.2.12_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.2.12_Setup.exe
Indigo for Linux 32-bit:
indigo_v2.2.12.tar.gz
Indigo for Linux 64-bit:
indigo_x64_v2.2.12.tar.gz
Changelog:
2.2.12:
* Fixed SSS bug with self intersection on some meshes.
* Fixed crash on image save failure.
Re: Indigo 2.2.12
Post by Zom-B » Fri Jan 08, 2010 12:00 pm
Thanks a lot for the crash fix!
Re: Indigo 2.2.12
Post by pixie » Fri Jan 08, 2010 12:55 pm
Thank you :)
Re: Indigo 2.2.12
Post by OnoSendai » Mon Jan 11, 2010 1:18 pm
Added linux builds to original post.
psor
Re: Indigo 2.2.12
Post by psor » Mon Jan 11, 2010 1:23 pm
Thank you! ;o))
take care
psor
Re: Indigo 2.2.12
Post by StompinTom » Tue Jan 12, 2010 12:34 am
Thanks! Off to play...
olafmar
Re: Indigo 2.2.12
Post by olafmar » Wed Jan 13, 2010 9:50 pm
May I suggest an option to limit the number of processors used? I share the rendering computers with other people and the priority may not be enough since the other users are also changing the processes priorities.
rendigo
Re: Indigo 2.2.12
Post by rendigo » Thu Jan 14, 2010 1:00 am
olafmar wrote:May I suggest an option to limit the number of processors used? I share the rendering computers with other people and the priority may not be enough since the other users are also changing the processes priorities.
indigo_console -t N
will use N render threads. Is this what you meant?
olafmar
Re: Indigo 2.2.12
Post by olafmar » Fri Jan 15, 2010 1:24 am
I am already using it for the network slaves, I would like to have something similar in the GUI... I play with the lights during the rendering, therefore I cannot start everything from command line.
I realise now I could use the GUI as non working master and have a slave on the same machine, but I still think that the option could be useful also inside the GUI (and effective only on the local gui/render process).
Re: Indigo 2.2.12
Post by Zom-B » Fri Jan 15, 2010 1:45 am
olafmar wrote:I play with the lights during the rendering, therefore I cannot start everything from command line.
You can also start the inigo.exe via commandline :)
olafmar
Re: Indigo 2.2.12
Post by olafmar » Fri Jan 15, 2010 3:29 am
I have a mac: if I use the cmdline to control the number of threads, I get the cmd line version, without preview or such. Or at least this is what I know...
Re: Indigo 2.2.12
Post by Zom-B » Fri Jan 15, 2010 3:37 am
olafmar wrote:I have a mac: if I use the cmdline to control the number of threads, I get the cmd line version, without preview or such. Or at least this is what I know...
try to "crack open" the link to start Indigo via rightClick and... hmmm... forgot it, working on vista on my iMac 95% of the time.... somehow you can edit this file and change the settings here with the texteditor. I once get it to work successfully this way!
Re: Indigo 2.2.12
Post by OnoSendai » Fri Jan 15, 2010 10:04 am
olafmar wrote:I am already using it for the network slaves, I would like to have something similar in the GUI... I play with the lights during the rendering, therefore I cannot start everything from command line.
Which exporter do you use?
Most exporters can set the number of threads.
Re: Indigo 2.2.12
Post by pixie » Fri Jan 15, 2010 10:27 am
Would it hurt to have something like this? It could be handy, doing some tweaks here and there, and in some cases for those features the exporters don't support.
For example, my exporter doesn't suport frame upload period, and having added it to the infile.xml had no effect, this way it could be a handy way to tweak the xml and set it there.
Re: Indigo 2.2.12
Post by OnoSendai » Fri Jan 15, 2010 10:33 am
You mean a way to modifiy all settings in the GUI?
