Xman
by Xman » Fri Jan 12, 2007 9:46 pm
Hi Nick,
I can't use the Indigo 0.7,why? Can you tell me?
thank you
____Xman
by OnoSendai » Fri Jan 12, 2007 9:54 pm
xman: u need to add <normal_smoothing>true</normal_smoothing>
to each mesh element in the xml.
by fused » Fri Jan 12, 2007 9:57 pm
read the first post
You'll need to add
Code:
or
Code:
<normal_smoothing>false</normal_smoothing>
to each mesh element.
and remove it from the <model> element.
the other stuff might be important too. youll have to do a lot xml editing...
edit: ah.... too slow
manitwo
by manitwo » Sat Jan 13, 2007 12:51 am
thanks for the answer nick
Xman
by Xman » Sat Jan 13, 2007 2:43 am
Thank nick and fused
dsp_418
by dsp_418 » Sat Jan 13, 2007 7:21 am
I've added <normal_smoothing>true</normal_smoothing> but it doesn't works ...
zsouthboy
by zsouthboy » Sat Jan 13, 2007 8:32 am
Remember to remove the offending tags that indigo gives you an error about! Indigo doesn't just ignore errors in the XML now...
BZ Win
by BZ Win » Sat Jan 13, 2007 10:42 am
Gosh, I am too tired, when I read:
There's a metric fuckton...
I was trying to figure out if that came before or after the deca prefix :E
by CTZn » Sat Jan 13, 2007 3:08 pm
atmmatt
by atmmatt » Sat Jan 13, 2007 4:46 pm
I get a bad cold for a couple days and I come back to 4 pages of bliss!
And I thought I would be spending the next couple days working in the shop....Ha!
Thanks a bunch ono!
"To be, or not to be" That is a question?
Kojack
by Kojack » Sat Jan 13, 2007 9:31 pm
impressive work Nick.
thx
Mute
by Mute » Sun Jan 14, 2007 1:49 am
i have added
in my xml files but a fatal error appears
SceneLoaderExcep: Rotation matrix must be orthogonal
by CTZn » Sun Jan 14, 2007 4:43 am
Thats not correlated
but I don't use rotation matrix so I cant help you
Behrendt
by Behrendt » Sun Jan 14, 2007 11:54 am
Has somebody tried to apply an SSS-Material to a human-model? Kinda interessted how this would look
by OnoSendai » Sun Jan 14, 2007 8:23 pm
Added some updated documentation, see the link under the changelog in first post.
Still incomplete, but i'm getting there
Let me know if there's anything anyone desperately needs documented.
nik
