0.9 test 8 Linux build (32 and 64 bit)
Post by Kram1032 » Thu Oct 18, 2007 9:03 am
normal smoothing, I bet...
your model appears to be very edgy. Try to sub surf it twice ;)
Oh, and if you use blender, you should also use the Edge split modifier ;)
Genscher
Post by Genscher » Thu Oct 18, 2007 9:07 am
@Kram1032:
Thanks for your quick reply. Yes, I use Blender of course. And you're right, it looked like some normal problem.
Thanks for your advise!
Post by Kram1032 » Thu Oct 18, 2007 9:15 am
No problem ;)
That's a typical ever-day problem.
If you look exactly, those issues also happen in the blender-internal renderer.
There, you don't get black artefacts, but it simply looks *odd*
But ok, how would you possibly smooth a, say, 90° edge, so that it appears like a smooth bevel? ;)
joegiampaoli
Post by joegiampaoli » Thu Oct 18, 2007 9:19 am
jurasek wrote:
joegiampaoli wrote:Can anyone please help me confirm resuming a scene? It doesn't seem to work here.....
dosen't work here too...
greetz,
jur
Ah, thx Jurasek
Joe Giampaoli
My Indigo Gallery
zsouthboy
Post by zsouthboy » Thu Oct 18, 2007 9:23 am
Those are normal smoothing issues, not shadows.
Split your model along the smoothing groups edges - for example, in Blender, add an "EdgeSplit" modifier.
Genscher
Post by Genscher » Thu Oct 18, 2007 10:11 am
Hey,
all working fine with EdgeSplit / Subsurf.
Thanks alot!
And: Great Linux 64 build! :D
Labello
Post by Labello » Sun Oct 28, 2007 2:14 am
This version does fucking rule! but i'm not shure whether i stick to indigo or change to Lux... i will see
Post by Kram1032 » Sun Oct 28, 2007 8:06 pm
But if you have Linux 64bit, this isn't the last version.... ;)
melonmelon
Post by melonmelon » Fri Nov 16, 2007 10:14 am
Works fine under 64-bit Ubuntu Linux (2 core proccessor) but...
For some reason CPU load never reaches 100% while under wine indigo takes all cpu power.
I'll do some speed comparisions, and let you know which version is faster.
Post by Kram1032 » Fri Nov 16, 2007 10:26 am
use more threads ;) It might be de to multi- , hyperthreating :)
thisisicejoe
Post by thisisicejoe » Sun Nov 18, 2007 4:20 pm
hey when i try to run indigo_console it says
" joe@linux-k6i0:~>
Indigo Renderer v0.9 test 8, Linux 64-bit Release build.
IniFileExcep: could not open file 'inifile.txt'.
Fatal Error: IniFileExcep: could not open file 'inifile.txt'. "
how do i get around that, i've tried permissions but no dice.
joegiampaoli
Post by joegiampaoli » Sun Nov 18, 2007 7:43 pm
thisisicejoe
I strongly recommend you to download and use the windows indigo under wine.
The linux port you downloaded is the very first one built for linux and it's still buggy. Here's a small tut I wrote on how to set it up under wine.
http://www.indigorenderer.com/joomla/fo ... php?t=2921
Joe Giampaoli
My Indigo Gallery
WytRaven
Post by WytRaven » Sun Nov 18, 2007 10:34 pm
Native linux builds never gave me any trouble whatsoever joe. My only issue is that the native builds have stopped...instaead I am forced to use a 32bit windows version on 64bit linux :shock:
joegiampaoli
Post by joegiampaoli » Sun Nov 18, 2007 10:35 pm
Have you tried resuming a render with the linux build? It doesn't seem to work with me..... :x
Joe Giampaoli
My Indigo Gallery
WytRaven
Post by WytRaven » Sun Nov 18, 2007 11:00 pm
@thisisicejoe:
You are cd-ing to the indigo folder before attempting to invoke ./indigo_console right?
Users browsing this forum: No registered users and 67 guests
