Indigo Renderer 3.8.8
12 posts • Page 1 of 1
Post by OnoSendai » Tue Aug 05, 2014 9:40 am
This is just a minor release to support SkIndigo object scattering.
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.8.8_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.8.8_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.8.8.tar.gz
Indigo for Mac OSX (10.6 - 10.8 ):
IndigoRenderer3.8.8.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.8.8_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.8.8_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.8.8.tar.gz
Indigo RT for Mac OSX (10.6 - 10.8 ):
IndigoRT3.8.8.dmg
Changelog:
3.8.8
* Made shader optional for scatter.
* Added offset_uids option for <include> tag.
DJ AntOn
Re: Indigo Renderer 3.8.8
Post by DJ AntOn » Tue Aug 05, 2014 9:02 pm
when we see pure GPU rendering in Indigo Renderer version?
Post by Zom-B » Tue Aug 05, 2014 9:24 pm
DJ AntOn wrote:when we see pure GPU rendering in Indigo Renderer version?
When its done! ;)
Post by OnoSendai » Fri Aug 08, 2014 12:11 am
Updated build in place, new changelog:
3.8.8
* Made IGS XML element checking print a warning message to the render log / std out, instead of causing an error and stopping the scene loading.
This will allow the possibility of older Indigo versions rendering scenes saved for new IGS formats.
* Added orient_normal option for scattering.
Post by Zom-B » Fri Aug 08, 2014 12:21 am
OnoSendai wrote:* Added orient_normal option for scattering.
That sound handy!
Is this value a on/off setting, or can it be controlled 0-100%?!
Post by OnoSendai » Fri Aug 08, 2014 12:23 am
That sound handy!
on/off.
tar_gniK
3D Software: 3ds Max
Post by tar_gniK » Sun Aug 10, 2014 12:14 am
Quick note, you may want to update the installer for IndigoMax in the executable. Version in the install file is 0.37, while most recent is 0.3.11.
Only realised when I updated Indigo, started Max, and an old IndigoMax Material Editor bug had returned. Had to manually update eventually.
Post by OnoSendai » Sun Aug 10, 2014 2:00 am
Updated build in place:
* Added support for object scatter groups.
* Added scale_std_dev and height_std_dev to scatters.
Post by StompinTom » Tue Aug 12, 2014 1:52 am
OnoSendai wrote:Updated build in place:
Awesome! Sample code?
Post by OnoSendai » Tue Aug 12, 2014 1:59 am
<scatter>
    <name>the scatter</name>
    <proto_object_groups>
      <proto_object_group>
         <prototype_object_uid>4000</prototype_object_uid>
         <weight>1</weight>
      </proto_object_group>
        <prototype_object_uid>5000</prototype_object_uid>
        <weight>0.1</weight>
    </proto_object_groups>
    <density>20</density>
    <scale_std_dev>0.0</scale_std_dev>
    <height_std_dev>0.0</height_std_dev>
    <target_object_uid>2000</target_object_uid>
    <evenness>1.0</evenness>
  </scatter>
or it can be done by referring to geometry and materials directly:
	<scatter>
		<uid>119</uid>
		<name><![CDATA[box on carpet base]]></name>
					<geometry_uid>118</geometry_uid>
					<materials>
						<material_uid>101</material_uid>
					</materials>
					<weight>1.0</weight>
					<transform><matrix>7.747000e-001 0.000000e+000 0.000000e+000 0.000000e+000 2.794000e-001 0.000000e+000 0.000000e+000 0.000000e+000 3.175000e+000</matrix></transform>
		<target_object_uid>116</target_object_uid>
		<density>20.0</density>
		<seed>1</seed>
		<view_culling>false</view_culling>
		<orient_normal>false</orient_normal>
		<evenness>0.5</evenness>
	</scatter>
Post by OnoSendai » Tue Aug 12, 2014 5:49 am
Updated build:
Added evenness setting to scatters.
Added per-scattered object (object group) transforms.
Post by Zom-B » Tue Aug 12, 2014 6:45 am
At some point you should update the initial changelog, thats quite a bunch for a silent update ;)
