dmn
by dmn » Thu Oct 29, 2009 6:39 am
The attached images have a difference I was not expecting. The scene has an emitter plane in a black diffuse tube pointed at suzanne. The only difference between the two scenes is that one has a specular emitter and the other a diffuse emitter. Why does the diffuse emitter emit so much more light? Why is the specular emitter so much more focused? Shouldn't they be of the same brightness? Does a specular emitter only emit once in the direction of it's normals, while the diffuse emits equally through 180 degrees from the normal?
And secondly why does suzanne appear to have specular reflection when the specular emitter is used, or is that just the way the render is accumulating? The suzanne model uses a diffuse white material.
- specular emitter
- im1256755044.png (142.48 KiB) Viewed 3697 times
- diffuse emitter
- im1256754059.png (913.36 KiB) Viewed 3698 times
benn
by benn » Wed Nov 04, 2009 8:34 am
That's a strange one - Ono is best suited to answer this.
by OnoSendai » Wed Nov 04, 2009 10:26 am
Could be a bug. Dmn, can you please simplifiy your scene, maybe so there's just one emitting triangle in a box?
SmartDen
by SmartDen » Wed Nov 04, 2009 10:59 pm
i don't have such issues. i tried with and without emission scale - same result
Check normals, dude!
dmn
by dmn » Thu Nov 05, 2009 10:40 am
I was running blendigo 2.0.10. Updating to v2.2.1 fixed the problem. It seems there was a bug, or an incompatibility. Thanks for the responses.
SmartDen
by SmartDen » Thu Nov 05, 2009 9:34 pm
dmn wrote:I was running blendigo 2.0.10. Updating to v2.2.1 fixed the problem. It seems there was a bug, or an incompatibility. Thanks for the responses.
therefore always write the version you use
dmn
by dmn » Fri Nov 06, 2009 4:44 am
Yeah sorry SmartDen. Or update to the latest version before posting about a problem. I should know that by now.
Users browsing this forum: Majestic-12 [Bot] and 8 guests
