End tag?
chubakueno
End tag?
Post by chubakueno » Wed Oct 07, 2009 10:56 am
I have a strange problem with the exporter.
Re: End tag?
Post by fused » Wed Oct 07, 2009 10:59 am
which exporter do you use?
Exporter version, Indigo version?
chubakueno
Re: End tag?
Post by chubakueno » Wed Oct 07, 2009 11:01 am
blendigo 2.2.1; indigo 2.0.12 for windows 32bit
benn
Re: End tag?
Post by benn » Wed Oct 07, 2009 12:44 pm
Can you please send us your .igm file via email to ben@indigorenderer.com?
Re: End tag?
Post by Borgleader » Wed Oct 07, 2009 1:11 pm
benn wrote:Can you please send us your .igm file via email to ben@indigorenderer.com?
I think he meant .igs
psor
Re: End tag?
Post by psor » Wed Oct 07, 2009 1:16 pm
chubakueno wrote:blendigo 2.2.1; indigo 2.0.12 for windows 32bit
Have you tried to use Indigo 2.2.1 or 2.2.2 with blendigo 2.2.1?
take care
psor
"The sleeper must awaken"
benn
Re: End tag?
Post by benn » Wed Oct 07, 2009 1:21 pm
Yes - the .igs file sorry :)
Also you should Indigo 2.2.1, as mentioned.
chubakueno
Re: End tag?
Post by chubakueno » Wed Oct 07, 2009 2:33 pm
One of my meshes have an accent in the name.Fixed.
edit:@ben, I have windows, as mentioned
psor
Re: End tag?
Post by psor » Wed Oct 07, 2009 2:54 pm
Ya that's something that has to be taken care of. It should be mentioned in the manual
that it's a nono to use special chars as name for anything. Maybe there is another way
around that. First hand it should be mentioned anyway. ;o))
take care
psor
Re: End tag?
Post by OnoSendai » Wed Oct 07, 2009 3:02 pm
Indigo has full Unicode support these days, it should work.
psor
Re: End tag?
Post by psor » Wed Oct 07, 2009 3:06 pm
OnoSendai wrote:Indigo has full Unicode support these days, it should work.
Then maybe the exporter is not taking care of it. ;o))
take care
psor
Re: End tag?
Post by OnoSendai » Wed Oct 07, 2009 3:06 pm
Yeah, might be a Blendigo Issue.
Re: End tag?
Post by suvakas » Wed Oct 07, 2009 9:13 pm
Really? It has never worked under my 64bit XP.
Just tested it. Indigo gives an error message if I try to use a texture file from this location (Dir name has an estonian char 'Ö' ):
<path>E:\Töö\texture.jpg</path>
Error: SceneLoaderExcep: Failed to load texture 'E:\T??\texture.jpg"
Re: End tag?
Post by PureSpider » Wed Oct 07, 2009 11:22 pm
Saved your IGS as UTF8? 8)
Might be why, if you didn't.
Re: End tag?
Post by suvakas » Thu Oct 08, 2009 2:16 am
PureSpider wrote:Saved your IGS as UTF8? 8)
Yep, that's it. Thanks.
Now I have to find a way how to output as UTF-8 from Max.
