I'm trying to achieve a lighting effect similar to the ones seen in this image:
http://www.indigorenderer.com/node/625?size=_original
However, from what I've learned from the manual and various forum posts, I've only been able to create a super-bright light source which washes everything out. I've tried just making a rectangle and adding a white material, and then tinkering with the temperature and power settings (multiple times), but it doesn't change anything.
Basically what I'm saying is, how would you make the lighting to achieve the effect in the image I linked to?
Creating Lights
Re: Creating Lights
First thing to do is check the scale of your model, if it is not realistically scaled it will be hard to get realistic lighting effects.
Other than that it looks as if you should be able to get a similar effect by positioning the sun correctly then using an exit portal material in place of the windows.
Re: Creating Lights
I think emitters have to be a volume, so add a cube instead of a plane.
Re: Creating Lights
Nope, they don't.FPSatan wrote:I think emitters have to be a volume, so add a cube instead of a plane.
Re: Creating Lights
Ah, this must be my problem, thank you.remus wrote:First thing to do is check the scale of your model, if it is not realistically scaled it will be hard to get realistic lighting effects.
Excuse my ignorance, but what's an exit portal material? Is this a term for a transparent/translucent material or some such thing?remus wrote:Other than that it looks as if you should be able to get a similar effect by positioning the sun correctly then using an exit portal material in place of the windows.
Re: Creating Lights
Its a material you can use in place of windows, it simulates light coming through a window but without the huge amounts of computation involved with having a realistically modelled window with light shining through it.
Re: Creating Lights
Hey, thanks, I was going to ask how you create an exit portal, but it's covered in your documentation. Thanks againbenn wrote:Ha ha!
http://www.indigorenderer.com/documenta ... ls|outline
I documented exit portals. ;D
