Some questions
13 posts • Page 1 of 1
Jambert
Some questions
Post by Jambert » Mon Jul 27, 2009 5:44 am
Hi all
1) How to export mesh as real instance and not as separated mesh? I tried "Alt D" instead of copy but it doesn't work!?
2) How to use displace? Do I have to use blender's displace and subdivision or can I just use blendigo mesh subdivision and displace as bump?
thx :?
Jambert
Re: Some questions
Post by Jambert » Tue Jul 28, 2009 8:42 pm
Do displace works in last 2.0.11 release? My tests give me crazy renders :(
benn
Re: Some questions
Post by benn » Tue Jul 28, 2009 9:26 pm
Heya Jambert,
Smartden is on holiday at the moment, so I'll get back to you tomorrow about these, unless anyone else can help>?
Jambert
Re: Some questions
Post by Jambert » Tue Jul 28, 2009 9:46 pm
benn wrote:Heya Jambert,
Ok thank for reply, I've done some captures
I think there is a bug with subdivision and subdivision smoothing in blendigo. If there's no bug, that mean I don't understand the use of subdivision in blendigo :roll:
Benn: Good night
Mesh subdivided in blender
result 2.png (465.04 KiB) Viewed 5837 times
Capture 2.PNG (198.48 KiB) Viewed 5831 times
Mesh subdivided with blendigo
result 1.png (433.64 KiB) Viewed 5837 times
Capture 1.PNG (353.09 KiB) Viewed 5836 times
Jambert
Re: Some questions
Post by Jambert » Tue Jul 28, 2009 9:58 pm
Ok I've tried with new map and things appears more clearly...
To make Subdivision in blendigo works, mesh must be more subdivided in blender than I did.
Re: Some questions
Post by suvakas » Wed Jul 29, 2009 12:06 am
Dividing the mesh in Blender kind of makes using Indigo displacement useless.
I'm not familiar with Blendigo, but try raising the "Max Num Subdivisions" parameter on Blendigo UI instead of subdividing the mesh in Blender. For a planar mesh like this you could aslo try to set the "curvature treshold" to -1 or 0. (not sure if it's allowed in Blendigo)
Jambert
Re: Some questions
Post by Jambert » Wed Jul 29, 2009 12:30 am
suvakas wrote:For a planar mesh like this you could aslo try to set the "curvature treshold" to -1 or 0. (not sure if it's allowed in Blendigo)
Thx Suv it works!!!
madcoo
Re: Some questions
Post by madcoo » Thu Sep 03, 2009 3:07 am
Jambert wrote:1) How to export mesh as real instance and not as separated mesh? I tried "Alt D" instead of copy but it doesn't work!?
What does it do when you do "Alt D" - does it create a new separate mesh?
If so, maybe it means that you can only use "Alt D" in Edit Mode only...
(i.e you will only create instances within a single object)
I don't really know, that's just an idea, you might want to check it out in Blenderclan's forum...
Anyway, if I remember well, creating instances without transforming them as real objects afterwards won't be recognised by Indigo as proper objects, and thus won't render.
But then again maybe I'm wrong...
If other people round here can say if I'm completely misleading Jambert, please do so!!! :mrgreen:
Visit my website!
http://www.fairview-3d.com Studio 3D
SmartDen
Re: Some questions
Post by SmartDen » Thu Sep 03, 2009 3:41 am
you are wrong. Alt D creates instances and indigo recognize them well as such. i don't really understand what we are discussing about.
@Jambert: if you still have problems, you can post an exmaple here
Check normals, dude!
madcoo
Re: Some questions
Post by madcoo » Thu Sep 03, 2009 3:49 am
Ok I got it all wrong!
:lol:
Well - at least I tried, and I learnt something at the same time!
Visit my website!
crestiksa
Some questions
Post by crestiksa » Sun Oct 25, 2009 2:19 am
Hi this is my first try, I will come up with more.
I have changed many things, mainly sampling strategy, spot lamps, the downlights are not longer mesh light but a shinydiffuse with emit, and I have started with this simple night scene, later Ill post some daylight.
SmartDen
Re: Some questions
Post by SmartDen » Mon Oct 26, 2009 9:48 pm
crestiksa wrote:Hi this is my first try, I will come up with more.
what are you talking about?! :shock:
dakiru
Re: Some questions
Post by dakiru » Mon Oct 26, 2009 10:10 pm
:lol:
edit: crestiksa, I think you forgot to post an image :wink:
