Grass Tutorial Anyone?
15 posts • Page 1 of 1
winnabago111
Post by winnabago111 » Tue May 12, 2009 10:30 am
I want to put grass in my scene and but render it in indigo so particles are out of the question.
I've only found one tutorial and it is out of date. Does anyone have another tutorial or a good way of doing it. Thanks.
Re: Grass Tutorial Anyone?
Post by Borgleader » Tue May 12, 2009 10:38 am
I posted a link in said outdated tutorial....might want to check that....
winnabago111
Post by winnabago111 » Tue May 12, 2009 10:53 am
Oh ok, I didn't see there was a sixth page.
And I watched it, but would I'm looking to create a field of grass like the one in the outdated tutorial. Do you think it would work.
Rafaello
Post by Rafaello » Tue May 12, 2009 10:57 am
You can make it with a patch of grass and then use the instancing technique, I saw a post with a patch somewhere in the forum, or you can make it with 3dsMax hair or Cinema Hair and convert the hair to polygons, if I find some free time I could make a patch or even a blender scene with it.
winnabago111
Post by winnabago111 » Tue May 12, 2009 11:00 am
I only use blender because I don't have anything else. When you say instanced do you mean to duplicate with ctrl-d.
Post by Borgleader » Tue May 12, 2009 11:06 am
He does exactly that if you watch the entire thing...All you'd have to do is scale the plane (top one in video) and increase it's grasse density then apply it onto your terrain and voila, it should be it.
winnabago111
Post by winnabago111 » Tue May 12, 2009 11:12 am
Ok I'll try.
Rafaello
Post by Rafaello » Tue May 12, 2009 11:21 am
Here you have a zip with the blender scene and you have to replicate the patch with alt-D this way Indigo takes it as instance
Pasto.zip
(771.76 KiB) Downloaded 417 times
winnabago111
Post by winnabago111 » Tue May 12, 2009 1:11 pm
Thanks for the file, and is there any way to lower the density so that my computer doesn't run super slow.
Rafaello
Post by Rafaello » Tue May 12, 2009 5:29 pm
Hi, if you download the file again you will find a new scene with lower density of grass
winnabago111
Post by winnabago111 » Wed May 13, 2009 5:40 am
I want the same density but that much slows down my computer. Is there a way to hide some of the grass or speed it up, but while still being able to see where its located.
handsomedave
Post by handsomedave » Wed May 13, 2009 5:53 am
change the display options for the object in blender
winnabago111
Post by winnabago111 » Wed May 13, 2009 8:20 am
What do you mean by change the display options.
Rafaello
Post by Rafaello » Wed May 13, 2009 9:04 am
If you yalk about the patch scenes I made the first one has 15000 "hairs" and a subdivision of 6, the second has 3500 "hairs" with 4 subdivisions, will it be fine 7500 hairs with 4 subdivisions? or you tell me and I can make the patch.
benn
Post by benn » Wed May 13, 2009 10:49 am
I started a wiki page at..
http://www.indigorenderer.com/wiki/grass_tutorial
If anyone wants to paste in some images and a lump of text I'll reformat it later on..
