problem with skindigo on mac
9 posts • Page 1 of 1
AtomAnt
Post by AtomAnt » Fri Nov 07, 2008 7:06 am
after getting mad half day to find out where i had to put the skindigo files (if someone wanna know: /Library/Application Support/Google sketchup6/sketchup/plugins and NOT in the plugins folder inside the sketchup package) i've got another problem I couldn't solve:
after running sketchup skindigo start but there is no way to see the html interfaces for render settings and material editor.
everything else is somehow working (some problem with paths in export because OSX in paths use "/" instead of "\", and no chance to render directly (i think is a problem that can be solved by making the script run indigo.exe trough darwine and as I'll have some spare time I'll make it and share it)
If anyone can help me I'll be really grateful...
"may you live in interesting times" antique chinese curse
dr_
skindigo on mac
Post by dr_ » Mon Dec 01, 2008 12:17 am
I did not come so far on my mac (leopard).
could you post how you make indigo.exe run on leopard?
here is what i did try already, using SkIndigo 1.1.12
1. I did install the plugin, and located indigo.exe.
It seems to work in SU but has no dialogs rendering ("Could not load Mozilla. HTML rendering will be disabled.") at all,
so I can't edit settings and view materials.
2. If i try to export it seem to do it, but then I get igs file butin wrong locaton, it seems to have some problem with path: instead of r.igs in Desktop i get Desktop\r.igs in home folder.
3. It does not render from inside sketch up.
After i did try:
4. run indigo via wine (indio 1.0.9 wine 1.0.1) it starts, start rendering then stops.
5. run indigo_console.exe via wine, it works correctly, it can handle igs files created in windows but not the one in mac for a "path" problem
6. the trick to substitute the path to indigo.exe with indigo_console.exe did not change the situation.
any hints?
What version of skindigo and indigo and wine do you use?
d
Post by Whaat » Mon Dec 01, 2008 4:05 am
I don't think SkIndigo will work on Mac unless you are running bootcamp or something like it. However, it might work on a Mac with SU7
dr_
Post by dr_ » Mon Dec 01, 2008 7:54 am
SU 7 ? you mean SU 6 ..., today the latest release.
It works but (on my system) with the problems described.
DR
Indigo console works with wine!
dr_
Post by dr_ » Mon Dec 01, 2008 10:29 am
sorry_ after longer google search i've found the version number 7
(today in italy not yet available from official site) from http://www.macupdate.com/download.php/1 ... hUpMEN.dmg
So downloaded and installed, installed again the plugin (did try SkIndigo_1_0_9 and SkIndigo_1_1_12) and does not work, exactly in the same manner...no interface...
I did update wine installation adding gecko (mozilla) via winetricks..
benn
Post by benn » Wed Feb 18, 2009 2:32 pm
I'm fixing up skindigo for mac at the moment. Join the beta group if you want access and also to the os x native indigo.
crojack
Post by crojack » Wed Feb 18, 2009 2:42 pm
benn wrote:I'm fixing up skindigo for mac at the moment. Join the beta group if you want access and also to the os x native indigo.
sweet!@ thanks Benn!! :D
bmscmoreira
Post by bmscmoreira » Fri Feb 20, 2009 9:36 am
All these great pieces of software coming to mac, that's really impressive. Thanks benn and ono and all of those working at this.
DonZ
Post by DonZ » Fri Feb 20, 2009 10:51 am
yes..THANKS FOR THAT...we love to use all this thing in MAC too...hopefully soon :)
