I'm not sure if this is a blendigo issue, but I'm trying to make a wheel, and have some weird issue with the bump map.
I've made a quick mesh from scratch with the same problem.
Blender 2.49a (same with b), blendigo 2.3.1, indigo 2.2.
Blend: http://www.home.no/faenskap/wtf.blend
Bump map: http://www.home.no/faenskap/yokobump.png
What the fish is going on? Check the attachments.
Bump map trouble
Bump map trouble
- With subd enabled in blendigo, ok except some bump map weirdness.
- subd.jpg (360.26 KiB) Viewed 4973 times
- With displacement map, looks funky too.
- disp.jpg (402.59 KiB) Viewed 4973 times
- With bump map.
- bump.jpg (436.91 KiB) Viewed 4974 times
- Render without bump map, all ok.
- nobump.jpg (401.56 KiB) Viewed 4976 times
- Wire, highlighted faces is UV layout.
- wire.png (66.43 KiB) Viewed 4975 times
Re: Bump map trouble
Displace is too strong, set it maybe 0.001 - 0.002 or soo (= 1 - 2 mm for font),
and displace needs mutch higher geometry, subdivide displaced area.
Increase the subdivision parameter for the displacement channel.
I cant remember how to do that - but hopefully Soup or Dougal will pop in here..
The point was to show what happens to the rest of the mesh, not the displacement.
I'm talking about the weird pattern when using only the bump map.
Every face gets a circle on it when rendered.
Here's some high geometry renders.
Blender modifiers applied.
Subd smoothing off in blendigo.
- Wire with UV layout.
- wire2.jpg (400.19 KiB) Viewed 4889 times
- Bump at 2mm. Same sized circle pattern.
- bump2.jpg (308.79 KiB) Viewed 4888 times
- Displacement .006, corner smooth. Probably not enough faces for this texture, but should it affect faces outside UV layout?
- disp2.jpg (302.28 KiB) Viewed 4888 times
What if u lower bump value <b>0.0001</b> <b>0.001</b>
Is the bump over sides or the whole tire, is there multible materials for same faces (under F9), delete those what's not assigned.
Is the object scale 1 (Ctrl+A in OB mode)
I think blenders default uv-mappping is to have full image for each quad. As you haven't uv-mapped the rest of the tire, each quad has the whole circular bump-map you've made for the side.
You'll need to unwrap the whole tire to get rid of those circles.
Here's an example
Here's an example
- 2.jpg (822.88 KiB) Viewed 4865 times
- 1.jpg (531.75 KiB) Viewed 4866 times
Ok, that's it.
I forgot that I deleted one of the materials to try with only one on the whole tire, without unwrapping the whole thing, then updated blendigo, then wasted a whole day on this, then....
