Indigo 2.4 - Don't Make Me Think
Re: Indigo 2.4 - Don't Make Me Think
Post by pixie » Mon Jan 25, 2010 11:54 am
galinette wrote:As a french user, I always customize my computer's locale to the decimal dot, as commas tends to mess around the anglo-saxon software behavior.
Nice soltion. Could you advise me on the program used to change the key?
galinette
Post by galinette » Mon Jan 25, 2010 9:17 pm
Actuall, I do not change my keyboard behaviour. I just go to Control Panel > Regional Settings > Customize, and then I set the decimal separator to "dot" instead of "comma". Then Indigo (and many scientific softwares...) works much better with number input.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by pixie » Mon Jan 25, 2010 11:35 pm
galinette wrote:Actuall, I do not change my keyboard behaviour. I just go to Control Panel > Regional Settings > Customize, and then I set the decimal separator to "dot" instead of "comma". Then Indigo (and many scientific softwares...) works much better with number input.
It worked as a charm, thanks!
Update: ui wise it works fine, but then the renders all become black :(
benn
Post by benn » Tue Jan 26, 2010 7:18 am
I hope this is a good idea... :twisted:
I've attached an excerpt of the Indigo .ui file for qt designer. If you want to have a go at creating a theme for the new Indigo GUI, download the QT Framework and install the designer. You can then click and drag to edit the ui, or edit the "stylesheet" parameter of the inspectorFrame to change the rounded-button style of the widgets.
Use this to generate a stylesheet that you'd like to use (we'll support custom ones in 2.4), or give us some ui ideas (bit more powerful than using a photoshop mockup). :)
sample-ui.ui.zip
(2.44 KiB) Downloaded 319 times
Soup
Post by Soup » Tue Jan 26, 2010 12:03 pm
Most renderers that I have used in the past render alpha at the same time as the rest of the image, saving as a jpg or other format that supports alpha channels save with the rendered alpha.
Can Indigo support this? It'd help composting really well.
Post by neo0. » Tue Jan 26, 2010 12:18 pm
The new UI is looking truly fantastic, benn. One small suggestion though.. The buttons look a little too rounded.. Rounded is still a great way to go, no argument there, but maybe tone down the rounded edges slightly?
Doug Armand
Post by Doug Armand » Tue Jan 26, 2010 3:31 pm
benn wrote:For @pixie and @doug:
This will be an optional theme in Indigo 2.4.
Love this colour scheme - very easy on the eyes :D
Doug
Doug Armand
galinette
Post by galinette » Tue Jan 26, 2010 9:50 pm
pixie : maybe you have a comma value in your igs that is not recognised anymore as you switch to dot?
Etienne
benn
Post by benn » Wed Jan 27, 2010 11:33 am
Added z-buffer and alpha as render modes in the indigo 2.4 gui.
Post by PureSpider » Wed Jan 27, 2010 11:45 am
Alpha as optional RGBA channel for png outputs?
Godzilla
Post by Godzilla » Wed Jan 27, 2010 12:19 pm
PureSpider wrote:Alpha as optional RGBA channel for png outputs?
Would be extremely helpful. :)
Post by Zom-B » Wed Jan 27, 2010 1:07 pm
Setting the default WhiteBalance for the test scene to F7 would be also great since it is to greenish atm, see this thread:
http://www.indigorenderer.com/forum/vie ... 712#p89712
>> http://www.indigorenderer.com/forum/vie ... f=5&t=8082
Godzilla
Post by Godzilla » Wed Jan 27, 2010 1:20 pm
Benn already said it's been added. :wink:
We're talking about an alpha channel which is embedded in the PNG image itself.
Post by Zom-B » Wed Jan 27, 2010 1:42 pm
seems I mixed up something here :oops: :lol: 8)
benn
Post by benn » Wed Jan 27, 2010 4:31 pm
I said it got added to my todo list :)
