Fixed crash-causing bug for Mac builds of Indigo
If you are using Indigo 2.0 on Mac - you should download the latest build from the downloads page. This version of Indigo 2.0.12 replaces the old release which had a bug with large scenes.
If you have had issues with Indigo crashing on your Mac, try this build.
This is a fix for the BVH bug if you've been waiting for it.
Re: Fixed cash-causing bug for Mac builds of Indigo
Erm, ... I guess you meant the version 2.2.1 will replace 2.0.12. At least I do read 2.2.1
on the download page. ;o))
take care
psor
take care
psor
"The sleeper must awaken"
- zeitmeister
Re: Fixed crash-causing bug for Mac builds of Indigo
Great, thank you very much!
- zeitmeister
STOP!!!!
Discovered something really important:
Indigo 2.0.12 doesn't run on my iMac here (iMac4,1 / 2GHz Intel Core Duo / 3 years old / 10.5.8)!!!
Indigo Icon is slashed, plus when I try to execute it it says:
"You can't run Indigo because it's not supported on this architecture".
My presumption:
Not all Intel-Macs are 64bit-compatible; you should provide a 32bit-build as an official version!
Indigo 2.0.10 is the last build running here on my machine.
And where has the render client app gone?
You really should check these things!
My presumption:
Zeitmeister - I'm doing a 32-bit build at the moment. It'll be available soon, my apologies.
- zeitmeister
Everything okay... didn't want to cause panic.
I was just astonished that the official download build didn't run here on 32bit-Intel-Macs; especially as it is the only available version to download for the Mac.
Where is the build that will work on my Mac?... I'm getting the same "Not supported on this architecture" message as zeitmeister when I try to install/run Indigo
17-inch Macbook Pro 2.16GHz Intel Core Duo... Mac OS X 10.5.8...
I downloaded the only one that was available for the Mac, and it doesn't work... and on your "features" page you state that software supports 32bit and 64bit
help
help
- Not supported.jpg (71.08 KiB) Viewed 2406 times
hello all - I'm getting this exact problem on an old imac running 10.5.7 osx - I'll download new installer, plese let me know if there are any other hidden bugs - will keep yall posted if it works.
thanks
thanks
I'll look into this today.
