End tag?
chubakueno
End tag?
I have a strange problem with the exporter.
- error.JPG (14.95 KiB) Viewed 14756 times
Re: End tag?
which exporter do you use?
Exporter version, Indigo version?
chubakueno
Re: End tag?
blendigo 2.2.1; indigo 2.0.12 for windows 32bit
Re: End tag?
Can you please send us your .igm file via email to ben@indigorenderer.com?
- Borgleader
Re: End tag?
I think he meant .igsbenn wrote:Can you please send us your .igm file via email to ben@indigorenderer.com?
Re: End tag?
Have you tried to use Indigo 2.2.1 or 2.2.2 with blendigo 2.2.1?chubakueno wrote:blendigo 2.2.1; indigo 2.0.12 for windows 32bit
take care
psor
"The sleeper must awaken"
Re: End tag?
Yes - the .igs file sorry
Also you should Indigo 2.2.1, as mentioned.
chubakueno
Re: End tag?
One of my meshes have an accent in the name.Fixed.
edit:@ben, I have windows, as mentioned
Re: End tag?
Ya that's something that has to be taken care of. It should be mentioned in the manual
that it's a nono to use special chars as name for anything. Maybe there is another way
around that. First hand it should be mentioned anyway. ;o))
take care
psor
take care
psor
Re: End tag?
Indigo has full Unicode support these days, it should work.
Re: End tag?
Then maybe the exporter is not taking care of it. ;o))OnoSendai wrote:Indigo has full Unicode support these days, it should work.
take care
psor
Re: End tag?
Yeah, might be a Blendigo Issue.
Re: End tag?
Really? It has never worked under my 64bit XP.OnoSendai wrote:Indigo has full Unicode support these days, it should work.
Just tested it. Indigo gives an error message if I try to use a texture file from this location (Dir name has an estonian char 'Ö' ):
<path>E:\Töö\texture.jpg</path>- PureSpider
Re: End tag?
Yep, that's it. Thanks.PureSpider wrote:Saved your IGS as UTF8?
Might be why, if you didn't.
Now I have to find a way how to output as UTF-8 from Max.
Users browsing this forum: No registered users and 106 guests
