What do you think is happening here?
12 posts • Page 1 of 1
mcompton
Post by mcompton » Fri Sep 11, 2009 6:26 am
I keep getting these fractals in my renderings...using the face style "monochrome", I can verify that my faces aren't reversed...please advise
fractals in renderings
remus
Re: What do you think is happening here?
Post by remus » Fri Sep 11, 2009 6:44 am
Looks like something weird might be going on with your mesh, any chance you could post an offending section of model?
mcompton
Post by mcompton » Fri Sep 11, 2009 7:26 am
remus wrote:Looks like something weird might be going on with your mesh, any chance you could post an offending section of model?
interesting enough...when I deleted the rest of the model to send you just the offending pieces...I rerendered and no fractals...is there a size limitation to Skindigo?
Post by fused » Fri Sep 11, 2009 7:36 am
its maybe a scale related problem. is the object realistically scaled?
Stinkie
Post by Stinkie » Fri Sep 11, 2009 8:04 am
I was thinking the same thing. His model may be far too big.
Post by Whaat » Fri Sep 11, 2009 9:50 am
Z-fighting? Maybe you had some coincident faces and you deleted them before you re-rendered?
I hope you can reproduce this problem and post the scene here. I'm very curious about what the problem is.
benn
Post by benn » Fri Sep 11, 2009 10:40 am
mcompton - nice model btw. Do you work for an architect or? Are you using 2.2 or 1.1.18?
Post by fused » Fri Sep 11, 2009 10:44 am
In the other thread he stated that he uses 1.1.16 :)
An update was already recommended....
mcompton
Post by mcompton » Tue Sep 15, 2009 6:19 am
Yes it is appropriately scaled...1'= 1' and yes I am an architect using 1.1.16
Still getting the fractals when all models are together in the site...in addition I am now getting this message:
"Finished building tree.
AutoFocus: setting camera focus distance to 141.46155 m.
Error: IndigoDriverExcep: Memory allocation failure while allocating master buffer.
Stopped."
PLEASE HELP!!! :( :( :(
benn
Post by benn » Tue Sep 15, 2009 10:10 am
Hi mcompton,
The fractal issue is either a z-fighting issue like Whaat said - or if that is not the problem, then it will be a bug with incorrect triangle intersections in Indigo. This issue was fixed in 2.0.6, can I recommend you download 2.0.12 and see if that corrects your issues?
http://www.indigorenderer.com/dist/beta ... _Setup.exe
The latest bug you reported is that you are running out of memory. How much memory do you have in your PC?
I hope we can get this fixed for you!
Ben
psor
Post by psor » Tue Sep 15, 2009 1:24 pm
@benn
I might be ignorant, but why shouldn't he download Indigo v2.2.1? :? :wink:
take care
psor
"The sleeper must awaken"
benn
Post by benn » Tue Sep 15, 2009 2:59 pm
2.2.1 would be even better :)
