change DOF
change DOF
How to change Dof during an animation, instead of doing it manualy. Does the value is linked to a blender value?
Thx
Thx
Re: change DOF
In fact you can link it to a object
Well u can Set your "DOF object" to the camera to a "empty" for example,
After that anime the empty and play a little with the nodes to have a nice DOF animated
Happy Blendin
Happy Blendin
- DOF.png (96.54 KiB) Viewed 8655 times
Re: change DOF
I'm not realy sure to understand, what do you mean by node? is it realy export with blendigo?164lndj wrote:In fact you can link it to a object
Happy Blendin
- Borgleader
Re: change DOF
Kinda sounds like you're talking about the node editor inside BlenderJambert wrote:I'm not realy sure to understand, what do you mean by node? is it realy export with blendigo?164lndj wrote:In fact you can link it to a object
Happy Blendin
Re: change DOF
64Indj - if you:
1. Select Focus distance: "Camera" in Blendigo
2. Press F9 and specify a depth-of-field object (Dof ob) in the Camera controls for blender
3. Then the camera will always focus on the object specified
4. Set the object to have a null material and you can use it to control the depth of field effect
Ben
Ben
Re: change DOF
Jambert wrote:How to change Dof during an animation, instead of doing it manualy. Does the value is linked to a blender value?
Thx
Benn it's right
Happy blending ...
Re: change DOF
Thanks for this Ben, that kind of exemple could be in manualbenn wrote:64Indj - if you:
Ben
Re: change DOF
What about light? can I change light value when the camera move?
Re: change DOF
you should just animate it - add an DOF IPO curve to the cameraJambert wrote:How to change Dof during an animation, instead of doing it manualy. Does the value is linked to a blender value?
Thx
Check normals, dude!
Re: change DOF
Looks easier, thanksSmartDen wrote:you should just animate it - add an DOF IPO curve to the cameraJambert wrote:How to change Dof during an animation, instead of doing it manualy. Does the value is linked to a blender value?
Thx
and light?
Users browsing this forum: Google [Bot] and 3 guests
