Any suggestions is very velcome
Render Book(Stromberg)
Re: Render Book(Stromberg)
Yeah, i had this rendering over night... and all this glass and refelctive surfaces is going to kill my pc
If you think it sucks just tell me, it's better to tell me than lett me working and posting updates on a bad render
I think it looks good so far.
the only crit i have is that those black dots on the joints to the shower look kind of wierd.
Nice to see you trying to make use of bump maps for realism Strom.
Here's a few pointers though:
1. I think I mentioned before that for small objects where scratching is really fine you need to use very high res bump maps and very little, if any, blurring of the scratch map. If you look at this image you will see that the "scratching" actually looks more like corrosion or like it's been sprayed with acid or something and I would be willing to be that is either blurring of the scratch map or way to low resolution of the map.
2. When it comes to making a scratch map think a lot about the actual object in use. Think about where it would get scratched most etc. In the case of these nuts, think about the fact that they are used by applying a metal tool to the flat sides and turning. That process often involves slipping and scrapping as the tool is applied. So my point is that here you have a very sudden lack of scratch on those flat surfaces where scratching is actually likely to be fairly high. the most scratched part of a nut is likely to be the vertical edges of the hexagon points. that shit is going to be cut up bad from spanner slippage etc. Nothing beats grabbing a real world equivalent and inspecting it for reference. Also I think that in general the scratch map is still being applied too strong. Tone it down by at least half for a start.
That said it really is good to see how you are actively taking on the advice provided by people here and applying it. Keep this rate of development up and I'll be coming to you for help before long
Your dedication to the art is about 10 times mine
(note to self, must spend more time developing modeling and rendering skills to avoid being eclipsed by Stromberg)
Thanks for the comments WytRaven, they are realy usefull
I know there is some problems with this map, planing to paint one by hand this time, with a regular brush this time i did use scratch brushes.
The map is 4096 x 4096 but the brush is quite low res.
Going to find more reference pictures to see where the scratches is taking place.
Thanks for the help
Thanks for the help
Sorry for not have done alot on this, as it was only ment for a quick test.
One more object for my bathroom you could say
- PureSpider
I love the kitchen and the day cream is cool! Looking very real
The kitchen is awesome! Looks like one my friend had in his apartment.
Glad you liked it, more to come later
Users browsing this forum: No registered users and 66 guests
