"menu" Water Jug. Indigo Competition wip
matsta
Re: "menu" Water Jug. Indigo Competition wip
Post by matsta » Tue May 12, 2009 10:56 am
Test with floor, what you guys think. i prefer the plane personally.
test
Jug with Lemon Floor Small.png (328.58 KiB) Viewed 3746 times
Post by Borgleader » Tue May 12, 2009 11:09 am
Well i think the compo is a little boring on this one. Rotate your camera (on the z axis) to the right a bit so that the jug isnt quite so centered (a render where the subject of your render is centered usually makes for boring composition, or so my photography teacher tells me, and on that point i tend to agree). I would also add some sort of kitchen wall not too far behind and a more yellow lighting (daylight/dusk)
benn
Post by benn » Tue May 12, 2009 11:23 am
I think the plane looked better too - focused more on the jug, and also - water jugs don't belong on the floor. :D
matsta
Post by matsta » Tue May 12, 2009 11:45 am
too true benn, tables are for jugs... not for asses XD
matsta
Post by matsta » Tue May 12, 2009 12:14 pm
Update, edited the post pro, this is pretty close to final, barring any water droplets i decide to throw in, probably only later this week though, got lots on my plate atm.
MORE MORE i wana see more stuff guys, post post. lol think the indi old timers have a lime fetish. why dont we all just render limes XD, change the competition focus.
Water Jug with Lemon Small.png (406.85 KiB) Viewed 3721 times
Post by zeitmeister » Tue May 12, 2009 7:43 pm
Limes rock! :-D
Yours are looking so beautiful, matsta!
I didn't use SSS yet, but I will have to. Due to my light setup, my limes cast and receive too much shadow... that's why they look so odd.
@fused:
I have absolutely no idea how to use SSS; I think I'll solve it with a blend material, of course... hm.
Can you tell me anything about Cindigo material conversion and SSS?
After 14 hours... :-)
Stromberg
Post by Stromberg » Tue May 12, 2009 8:51 pm
Looks good, but would be nice to have some caustics on that window frame there :)
Post by zeitmeister » Tue May 12, 2009 9:10 pm
Yeah, I will definately have to change the light setup to something more subtle, more focused on the bottle but the window.
Post by zeitmeister » Tue May 12, 2009 10:43 pm
Hm, I think I know where my problems come from.
What material do you use for glass and water? "specular" or "glossy transparent"?
In my case, the glass and the water in junction cause too many shadows on the limes.
Can anyone give me a hint how to achieve such clear materials like matsta?
And matsta, did you place the water mesh between the glass mesh or inside?
Post by lycium » Tue May 12, 2009 10:46 pm
also: limes aren't spherical :wink:
zeitmeister, there's some crunchy aliasing in your image - a bit more image supersampling or less photoshop sharpening would do the trick.
Stromberg
Post by Stromberg » Tue May 12, 2009 10:48 pm
I think it's the lights in he's case that makes it look so clear, and because we see the image quite right on, so the refraction dosnt seam like it's so much.
But there may be another explanation :P
Post by zeitmeister » Wed May 13, 2009 12:35 am
Hm.
With SSS they do come out a little bit better, but only if I render without the water.
Can anyone give me a hint what material you use for water?
I used all the real refraction indices according to the tables that go around the net...
matsta
Post by matsta » Wed May 13, 2009 1:10 am
lol tom, the lime i saw was pretty round :P swear ;)
Post by zeitmeister » Wed May 13, 2009 9:17 pm
A little preview of my inner lime material...
2 blend materials, blend-, diffuse- and bumpmap with diffuse transmitter instead of real sss.
Working pretty well at the material preview scene, but not in my water jug scene...
I really got major lighting problems. :-(
It seems like the diffuse transmitter material doesn't work proper inside the water material; a simple specular transparent. It absorbs too much of the light... hm.
matsta
Post by matsta » Thu May 14, 2009 12:45 am
Hey zeit, post your light setup? Ill have a look and see if i have any suggestions, my emmiters worked just fine with spec trans mat of the glass and water. Not quite sure why your are having troubles.
Regards.
