Indigo 2.0.0 betas are available!
For all Indigo users.
Re: Indigo 2.0.0 betas are available!
Post by fused » Wed Apr 22, 2009 3:26 am
Whaat wrote:This will be a problem for me when I do material preview renders with SkIndigo. Maybe a switch to determine if Indigo starts rendering immediately after opening the scene file?
I also thought that this migh interfere with my preview stuff in cindigo. have you just tried it? maybe when launched with parameters it will just start rendering? going to try it now.
Post by pixie » Wed Apr 22, 2009 3:31 am
This new build is a bit faster then before, at least 23% more :-D
100k against 123k on the same machine in diffuse transmitter test
Post by fused » Wed Apr 22, 2009 3:56 am
pixie wrote:This new build is a bit faster then before, at least 23% more :-D
compared to? 1.1.18? or 2.0.1?
Post by pixie » Wed Apr 22, 2009 4:03 am
1.1.18, I'm not worthy enough to get that kind of builds :lol:
Post by fused » Wed Apr 22, 2009 4:05 am
fused wrote:I also thought that this migh interfere with my preview stuff in cindigo. have you just tried it? maybe when launched with parameters it will just start rendering? going to try it now.
Whaat,
it works fine with the indigo_console.exe (which i use) but with the indigo.exe i get an empty error message.
Post by suvakas » Wed Apr 22, 2009 4:20 am
@Fused
What that means? We can't auto-launch the rendering with UI version anymore?
Post by neo0. » Wed Apr 22, 2009 4:51 am
Im a little confused as to the licensing system.. So, say I only wanted to get one copy of pro for myself.. which one would I get?
eman7613
Post by eman7613 » Wed Apr 22, 2009 5:33 am
Indigo GUI no longer works well under wine, which i would not have expected written in qt :(
No text shows up on anything, and if you try to resize the window, it gets locked in resizing mode and forces it to resize whenver you move your mouse in!
Edit: Also, all us poor students! noooo!
Yes i know, my spelling sucks
Post by fused » Wed Apr 22, 2009 5:35 am
suvakas wrote:@Fused
exactly, it does not work at the moment. i always get empty error messages when using the ui version.
Ono, please fix it :)
benn
Post by benn » Wed Apr 22, 2009 11:53 am
@neo0. A indigo full lifetime licence will do what you want. We probably need to clarify the wording on the licencing pages.
@eman. We will have student Indigo 2.x licences available once we have sold out of the lifetime licences.
@fused I'll let him know.
Post by OnoSendai » Wed Apr 22, 2009 11:56 am
When the GUI version is given a indigo scene path as a command line argument, it should open the scene and start rendering immediately.
Post by fused » Wed Apr 22, 2009 4:55 pm
yes, youre right. and it does work when running indigo from commandline.
but its not working with this batch:
@echo off
cd /d "H:\Indigo\indigo_x64_v2.0.2"
start /belownormal indigo.exe "I:\CINEMA 4D R10\plugins\cindigo_dev\quickrender\quickrender.igs"
when i use indigo_console.exe the batch works fine.
edit: it works for the indigo.exe too when i change it to:
@echo off
start /belownormal H:\Indigo\indigo_x64_v2.0.2\indigo.exe "I:\CINEMA 4D R10\plugins\cindigo_dev\quickrender\quickrender.igs"
but now its not working anymore if theres a space in the path to the indigo.exe...
carbon
Post by carbon » Wed Apr 22, 2009 5:46 pm
Post by Zom-B » Fri Apr 24, 2009 3:53 am
Its a shame to sell Indigo without answering this brutally important question first... :|
Post by OnoSendai » Fri Apr 24, 2009 12:26 pm
carbon wrote:ok, now it works..
but i have question, how about exporter developers? are you going to hire current developers? because Indigo, by my opinion, is unusable in real production without exporter of same great quality as rendering engine is. the new shiny gui is pleasant, but big button 'render' is nothing compared to, for example Blendigo's material editor and/or even more important geometry - to - indigo mesh conversion..
regards
c.
edit: don't take me bad, i am thinking seriously about purchasing indigo license, but the price you estimated is a bit higher than i was expecting (almost 2/3 of maxwell's price), so this question promptly came to my mind..
Hi Carbon,
We will continue to work with the current developers, as they are a key part of our future plans for Indigo. We are also planning to move the source code into a central repository, and spend some time improving and optimising the exporters. So I expect the exporters to improve in quality.
