impossible to install Indigo
8 posts • Page 1 of 1
alexandersimanov
Post by alexandersimanov » Sun Apr 19, 2009 12:13 pm
Hi everyone! I wonder if somebody can help me. I've been trying to install Indigo and it has been impossible. I'm sure it must be very easy, the instructions are quite clear, but I've tried four times with no results; I can't find Indigo in SketchUp plugins section. Maybe I am missing something...
Any help will be welcome.
benn
Re: impossible to install Indigo
Post by benn » Sun Apr 19, 2009 3:47 pm
Heya Alexander,
Did you follow the instructions here.. ?
http://www.indigorenderer.com/documentation/sketchup
Where did you install the plugin to?
Where are you looking for the sketchup menu?
Have you tried running sketchup on the command line and watch for any errors?
Ben
alexandersimanov
Post by alexandersimanov » Mon Apr 20, 2009 2:06 am
Hi Ben, Thank you for answering. As a matter of fact, I did follow the instructions from that link and its six steps. I installed the plugin into the SketchUp/plugin directory and I'm looking for it in the Sketch Up plugin menu. I have not tried yet running sketchup on the command line and watch for any errors, because I did not know about that feature. Would you please tell me how to get there.
Thank you in advance.
Pants9000
Post by Pants9000 » Tue Apr 21, 2009 3:20 pm
If you copied all the Skindigo files to the correct place in you file system, you should be prompted to locate indigo.exe on start up of SketchUp.
Out of curiosity, did you get the prompt?
benn
Post by benn » Tue Apr 21, 2009 10:37 pm
To run on the command line:
start -> run -> cmd -> enter
cd \program files\google sketchup
sketchup 7
That should show you some sketchup informations when it launches..
alexandersimanov
Post by alexandersimanov » Wed Apr 22, 2009 3:03 am
Thank you both for answering. Ben, I did what you told me to do, but the only I got is a black window that does not allow me to do anything else.
Pants9000, I get the prompt, but I can not locate Indigo.exe. I have even tried to locate it trough "search" with no results. I do not remember to have seen that file when I downloaded Indigo.
Pants9000
Post by Pants9000 » Wed Apr 22, 2009 3:41 am
Sounds like you installed Skindigo (the exporter) OK. As for Indigo (the renderer itself) not so much.
The way I installed Indigo.
-Downloaded Indigo
-Unzipped the download
-Placed the unzipped folder in C:/Program Files/Indigo/ (you can make the folder if it doesn't exist)
You now know exactly where indigo.exe is (it's in that unzipped folder you placed in Program Files)
-Run SketchUp
Let us know if this works for you.
alexandersimanov
Post by alexandersimanov » Wed Apr 22, 2009 3:54 am
Dear Pants9000, Thank you very much indeed!!! now it runs perfectly.
Alex.
