Blendigo 2.0.10
Re: Blendigo 2.0.10
I think that something has changed on the site, because the main menu doesn't display correctly in IE7.
I have installed Firefox 3.5, and I have been able to download the blendigo file.
Re: Blendigo 2.0.10
Still haven't figured it out, and I'm dying to start rendering again, people
Re: Blendigo 2.0.10
Well, I'm back after some simple exports tests done :
I'm happy to see that it is possible to set the path for the PNG rendered images (Thank you !), but it is really a shame that it is still not possible to do the same for the igi files which are still saved in the Documents and settings/Application Data path !
The main reason that led me to ask several times for this feature is that it is a bad thing to put data files on the main disk unit (C:), which is better to reserve to the OS and the softwares install.
As the igi files are much bigger than image files, they will still "pollute" the system disk rendering after rendering, if they are stored onto it.
I really need to be able to save all my work files (png and igi) at the same location on a different unit (D: for example), or better on an external disk.
So, please : in the next release, add a field to type also the igi path, or use the same path as png files location to save the igi files as well!
Re: Blendigo 2.0.10
Godzilla: did you try setting the PYTHONPATH environment variable?
Re: Blendigo 2.0.10
Godzilla:
try following the instructions in here: http://www.blender.org/forum/viewtopic.php?t=11938
At least about downloading Python, and then setting the PYTHONPATH environment variable.
Re: Blendigo 2.0.10
I up my problem, no issu at all...
- Capture.PNG (77.95 KiB) Viewed 4744 times
- pixie
Re: Blendigo 2.0.10
+1ROUBAL wrote:So, please : in the next release, add a field to type also the igi path, or use the same path as png files location to save the igi files as well!
In those systems with only one partition it's irrelevant, the problem arises when there's a dedicated system partition, in that case it's too easy to fill it up due to the igs and tree made... the only way is leave to the user continuously manage that drawer, which IMO not the best thing to do...
Re: Blendigo 2.0.10
I have the same problem when I try to preview a material, not that big of a deal to me though.Jambert wrote:I up my problem, no issu at all...
Re: Blendigo 2.0.10
Great I'm not alone...Godzilla wrote:I have the same problem when I try to preview a material, not that big of a deal to me though.Jambert wrote:I up my problem, no issu at all...
Re: Blendigo 2.0.10
I have this too.Jambert wrote:Great I'm not alone...Godzilla wrote:I have the same problem when I try to preview a material, not that big of a deal to me though.Jambert wrote:I up my problem, no issu at all...
Re: Blendigo 2.0.10
When I enable motion blur, it only exports the first frame of the animation no matter what frame the animation is set on. This doesn't happen when motion blur is turned off with all other settings the same. I haven't experimented with motion blur before--am I doing something wrong?
Re: Blendigo 2.0.10
Have some options been removed from mlt settings and general tracing parameters? All I'm seeing is MNCR and supersamples. And also seems like image display/ save period parameters are transmitting to the igs but not having any effect on Indigo. I set it to 8 minutes and it is going every 30 seconds.
Re: Blendigo 2.0.10
We've been working on some fixees for blendigo so it doesnt require python to be installed. It still requires blender 2.49, not 2.49a - we'll work on fixes for the latest blender after the 2.0 stable release.
Users browsing this forum: DotBot [Bot] and 11 guests
