Indigo 2.0.4
Indigo 2.0.4
Hi All,
The main difference in this version from 2.0.3 is that temporary files, plus the licence key will be saved to C:\Users\xxx\AppData\Roaming\Indigo Renderer (or equivalent on XP), to avoid problems writing to the Program Files dir on Windows Vista.
Please test and let me know if it works!
Windows 32 bit:
http://indigorenderer.com/dist/beta/Ind ... _Setup.exe
Windows 64 bit:
Windows 32 bit:
Windows 64 bit:
Re: Indigo 2.0.4
is ben not doing mac & linux builds? Would it help if i made a cross compiler for you
I usualy dont have a windows machine and indigo dosn't work well in wine anymore
Yes i know, my spelling sucks
Re: Indigo 2.0.4
There's no improvement in 2.0.4 for mac - i'll do a build for completeness later.
Re: Indigo 2.0.4
and linux? I cant imagine the code to make it work on mac and linux is much different now that qt is being used. Just a VM away!benn wrote:There's no improvement in 2.0.4 for mac - i'll do a build for completeness later.
Re: Indigo 2.0.4
@Ono
Please fix the command line scene loading for UI. Manual file browsing really sucks. I want to be able to auto-launch rendering directly from the exporter like it has always been. This empty error message as it is now is also very confusing for the users. A lot of people are thinking, that exporters are not compatible with 2.04 because of this.
Re: Indigo 2.0.4
Fixed for 2.0.5.suvakas wrote:@Ono
Re: Indigo 2.0.4
cool! Thanks. What about launching and Indigo scene on the Mac from the command line? Can it be done? Also, there is no 'indigo_console' for the Mac. Is it possible to have one? I don't quite understand what can be done yet with the 'Terminal' on a Mac but I'm trying to learn...OnoSendai wrote:Fixed for 2.0.5.suvakas wrote:@Ono
Re: Indigo 2.0.4
Yes, you can launch from the command line from mac and linux. The tricky bit is getting the directory that the executable is in.
The mac distribution will have an indigo_console eventually.
Re: Indigo 2.0.4
Great news !
Thanks Ono!
Thanks Ono!
