fer_menezes
by fer_menezes » Fri Aug 14, 2009 2:15 am
fused wrote:fer_menezes wrote:When i try to render in maximum resolution possible in the free version (0.7) appears the follow message of error "Error: ObjectExcep: Exception while building tree: BVH Build failure, too many triangles in leaf.", but only in the model i need to render, in oders models this message not appears.
In lower resolutions the render happens normal.
What means this message?
This isnt ram related. Which exporter do you use? is there an option called "BIH Threshold" or similar? Try to set it very very high (higher than the polycount of your model in tris). Indigo will then not use the BVH intersection accelleration structure anymore but the standard KD tree.
It will take a little longer to start the rendering then but the error should be gone.
i'm using the SkIndigo 2.0.10.
I can't find this option, it is in Render Settings? Where is it?
by fused » Fri Aug 14, 2009 2:29 am
I dont know if its supported by skindigo, but if you hand edit the igs file you should be able to find it inside the <renderer_settings> element. its called <bih_tri_threshold>.
best change it to <bih_tri_threshold>10000000</bih_tri_threshold>.
if its not there just add in the <renderer_settings> element
fer_menezes
by fer_menezes » Fri Aug 14, 2009 1:58 pm
fused wrote:I dont know if its supported by skindigo, but if you hand edit the igs file you should be able to find it inside the <renderer_settings> element. its called <bih_tri_threshold>.
sorry, but i have no experience and i can't find where i can edit the igs file.
but, thanks for trying to help me.
sehr danke
benn
by benn » Fri Aug 14, 2009 2:58 pm
Fer - is it possible for you to zip up and email me the sketchup file? I will not distribute the sketchup file - but we would like to resolve this bug for you.
ben@indigorenderer.com
Regards,
Ben
fer_menezes
by fer_menezes » Fri Aug 14, 2009 6:27 pm
benn wrote:Fer - is it possible for you to zip up and email me the sketchup file? I will not distribute the sketchup file - but we would like to resolve this bug for you.
Regards,
Ben
but how you can solve my problem?
i send you the file and then you send me back?
thanks
fer_menezes
by fer_menezes » Fri Aug 14, 2009 6:51 pm
There's any way that i can render in Indigo 1.0.9 and the waves not appears on parallel projection?
Simple models i render in parallel projection and the render goes normal, but if the model is a little more complex appears waves in the render. Because it i think there should be a way i render a complex model with Indigo 1.0.9.
I really need a large resolution, that's why i wanna render with the free version.
by OnoSendai » Sat Aug 15, 2009 12:15 pm
Try increasing ray_origin_nudge_distance.
by Whaat » Sat Aug 15, 2009 1:36 pm
OnoSendai wrote:Try increasing ray_origin_nudge_distance.
That setting is not supported by SkIndigo
by Borgleader » Sat Aug 15, 2009 1:44 pm
Whaat wrote:OnoSendai wrote:Try increasing ray_origin_nudge_distance.
open the .igs file and change it?
fer_menezes
by fer_menezes » Sat Aug 15, 2009 6:42 pm
Borgleader wrote:Whaat wrote:OnoSendai wrote:Try increasing ray_origin_nudge_distance.
when i render i just have a image file and a .igi file
where's this .igs file?
by Whaat » Tue Aug 18, 2009 3:17 am
From Indigo GUI go to Tools->Show Scene File in Explorer.
fer_menezes
by fer_menezes » Tue Aug 18, 2009 4:08 am
Whaat wrote:From Indigo GUI go to Tools->Show Scene File in Explorer.
thanks
i go there but i just found .igi files and .png files and none .igs files
by fused » Tue Aug 18, 2009 5:53 am
fer_menezes wrote:i go there but i just found .igi files and .png files and none .igs files
Really? When clicking on "Show scene file in Explorer" while rendering (you can only select it when a scene is loaded or rendering) it should show you the scene file...
Maybe you clicked on "Show render folder in explorer"?
fer_menezes
by fer_menezes » Tue Aug 18, 2009 8:42 am
fused wrote:fer_menezes wrote:i go there but i just found .igi files and .png files and none .igs files
i got it. thanks!
my render goes normal now.
thanks to all!!!!!
