Indigo for Revit Beta 4 Released with Revit 2011 Support
We are proud to announce the release of Indigo for Revit Beta 4. It now supports Revit 2011 and has many Improvements over the last release, such as:
- Added support for Revit 2011
- Fixed problem where no 3d Views where found in non English versions
- Added support for environment maps
- Fixed UV export
- I4R can now get the sun position from Revit (2011 only)
- Added support for arch glass acceleration
- I4R dialogs can now be closed by pressing ESC (cancels, changes wont be saved)
- I4R dialogs are displayed in the screen center
- Fixed issue where material browser would continue to Query materials after close
- Added material inspector
- Improved mesh export
- Optimised render settings
- Colour filter in lightsources now supported
- Fixed reflectivity slider
- Fixed issue where Topology Suface wouldnt have any texture coordinates
- Roughness material parameter behaviour improved
- Better error dialogs
You can download the Indigo for Revit installer packages from here: http://www.indigorenderer.com/revit/
It is also required that you update your Indigo installation to Indigo 2.6.1, which you can get from here: http://www.indigorenderer.com/forum/viewtopic.php?f=1&t=10245
