Indigo for Revit Beta 3 Released
Written Monday 23 Aug
We are proud to announce the release of Indigo for Revit Beta 3. It has many Improvements over the last release, such as:
- An updated material editor
- Online material database integration
- Better conversion of light sources, using temperature, light intensity and IES settings from Revit
- An improved Installer that installs the prerequisites, if needed, and also handles setting up the .ini file
You can download the Indigo for Revit installer packages from here: http://www.indigorenderer.com/revit/
It is also recommended that you update your Indigo installation to Indigo 2.4.10, which you can get from here: http://www.indigorenderer.com/forum/viewtopic.php?f=1&t=10130
