Layer bug
5 posts • Page 1 of 1
klopes
Layer bug
Post by klopes » Thu Dec 28, 2006 4:21 am
Hi, I'm Klópes, a blender user from Spain, and I carry a bug and a solution :wink: I hope it helps.
There's a problem at layer section:
the export script compares if the object layer is among the visible ones; it's not correct, from an object may be in several layers, then the resulting number is the sum. If this is the case, the object isn't exported as visible.
I've modified the code, it looks work now (comment lines are original). Please, verify it. Look for this section:
	#get all the objects in this scene
#	activelayers = Window.ViewLayer()
#	for i in range(len(activelayers)):
#		activelayers[i] = 2**(activelayers[i]-1)
	object_list1 = Blender.Scene.GetCurrent().getChildren()
	object_list = []
	matnames= []
	activelayers = sum(map(lambda x:2**(x-1), Window.ViewLayer()))
	for obj in object_list1:
		if obj.Layer & activelayers:
#		if obj.Layer in activelayers:
			object_list.append(obj)
			collectObjectMaterials(obj)
soxofaan
layer detection bug
Post by soxofaan » Sun Dec 31, 2006 2:39 am
I use a more pythonic way (without the sum-map-lambda-logic_and stuff):
	object_list = []
	matnames = []
	for obj in Blender.Scene.GetCurrent().getChildren():
		for layer in obj.layers:
			if layer in activelayers:
klopes
Post by klopes » Fri Jan 12, 2007 3:14 am
That's just the bug, soxofaan! If you ask for activelayers, you get a list of them. But if an object is in MORE THAN ONE layer, its "layer" is the sum of the layer numbers, so it is no more in that list!
Please, any moderator could move this thread to "blender" forum?
:roll:
soxofaan
Post by soxofaan » Fri Jan 12, 2007 11:04 pm
klopes wrote:That's just the bug, soxofaan! If you ask for activelayers, you get a list of them. But if an object is in MORE THAN ONE layer, its "layer" is the sum of the layer numbers, so it is no more in that list!
:roll:
hola klopes,
I'm aware of that. But the devil is in the details:
(see http://www.blender3d.org/documentation/ ... tml#Layers)
* obj.Layers (uppercase L) are the layers coded as a C-style bitmask, this is the thing you use
* obj.layers (lowercase l) is a python list of integers, referring to the layers the object is in, this is the thing I use
another indication the python API of blender needs some cleanup.... :wink:
regards
klopes
Post by klopes » Mon Jan 15, 2007 7:57 pm
:shock: oops. Ok, lets leave it for the moment... :?
