Modeling Water
13 posts • Page 1 of 1
cholme@me.com
Modeling Water
Post by cholme@me.com » Fri May 21, 2010 1:27 pm
I have seen some amazing renders of images with water. I was wondering if there is a tutorial or something available for how to model and render water. Specifically, I am designing a water feature and would like to give it a realistic look so I would need rippled water on the surface of metal. I would also love to know a technique for doing something with splashes.
Thanks for any help.
Soup
Re: Modeling Water
Post by Soup » Fri May 21, 2010 4:31 pm
SketchUp isn't really the best for modeling the fluidity of water. It's easy to make a box with a displaced surface, but if you want more dynamic looking water (ie: splashes) then you'll be better off using a different program. There are some great water simulation tools out there :)
FenixPheonix
Re: Modeling Water
Post by FenixPheonix » Sun May 23, 2010 7:08 pm
For instance, you could export the container from Sketchup to Blender, set up the simulation using that, and then export a frame of the resulting mesh back to Sketchup. I haven't tried it with water, but I've used it for some organic modeling I couldn't do in Sketchup. It'll be very high-poly, but well worth the effort. You could just hide it if it's too high poly for your computer to handle (which can happen. Sketchup isn't very good at taking huge amounts of polies.)
cholme@me.com
Re: Modeling Water
Post by cholme@me.com » Wed May 26, 2010 7:02 am
FenixPheonix - Thanks for the tip, it sound like a good plan... a couple problems. I downloaded Blender and it makes absolutely no sense to me. Any tips where to begin? And I am using a Mac, and there is not Blender/Indigo installer. Is there a way to get back to SketchUp from Blender?
Forgive me if I sound ignorant to a lot of this... I am a furniture maker, not a computer guy. I am pretty tech savvy, but the Blender UI just make no sense to me.
Thank again.
Re: Modeling Water
Post by Zom-B » Wed May 26, 2010 12:41 pm
I think some ISL based solution would do the best work here! Using Indigo Subdiv to get a (final) high poly count with displacement. By this you keep your Sketchup Polycount low!
If you are maybe start a Therad in the Material SubForum, you'll get some ideas from more skilled ISL guys around here. Galiante is the guy who puts such magic right out of his hat usually ;-)
cholme@me.com
Re: Modeling Water
Post by cholme@me.com » Fri May 28, 2010 11:08 am
Thanks for your input. I downloaded Blender and frankly it seems very difficult to use.
I know I may never get photorealistic in SketchUp, but it would be nice to get decent results. I tried modeling a glass of water and the water keeps rendering black. Is there something I am missing? I tried it flat and also with thickness.
Any Ideas?
Re: Modeling Water
Post by Headroom » Fri May 28, 2010 12:14 pm
The last two or three pages in the Indigo Technical Manual describe in detail what needs to be considered when modeling a glass of water. My guess would be that it's a precedence problem.
cholme@me.com
Re: Modeling Water
Post by cholme@me.com » Fri May 28, 2010 2:02 pm
Perhaps this is one of my problems... Technical Manual? I only have the SketchUp Manual. Where can I get the Technical manual? Under documentation on the website there seems to be only the manuals for the specific exporters.
Soup
Re: Modeling Water
Post by Soup » Fri May 28, 2010 5:24 pm
Clicking on the Documentation link will take you here: http://www.indigorenderer.com/documentation
cholme@me.com
Re: Modeling Water
Post by cholme@me.com » Fri May 28, 2010 6:44 pm
I see what was happening. On my computer, the pull down menu items don't open the actual page, just the pull down list which doesn't have the indigo manual.
Thanks for the info, I will read it.
cholme@me.com
Re: Modeling Water
Post by cholme@me.com » Sat May 29, 2010 10:04 am
Ok... I am doing something wrong... perhaps someone can help. I attached a SketchUp model and my rendering of a glass of water which I did according to the specs in the Technique Manual. I used 2 different materials for the Glass and Water, applied the presets in Indigo (Water and Glass accordingly) and it clearly is not working.
HELP!!!
Glass of Water.zip
SketchUp Model
(108.92 KiB) Downloaded 220 times
snorky
Re: Modeling Water
Post by snorky » Sat May 29, 2010 10:54 am
a storm in a teacup!
hehehehe
turn off soften edge from glass!
don't say a word... it's a netbook...
cholme@me.com
Re: Modeling Water
Post by cholme@me.com » Sun May 30, 2010 3:58 am
THANK YOU!!! I didn't think of that.
Users browsing this forum: No registered users and 89 guests
