Mini servo actuator
12 posts • Page 1 of 1
Phil
Mini servo actuator
Post by Phil » Sat Dec 23, 2006 12:42 am
after a lot of test and work, here is my finished artwork.
regards, Phil
iamthwee
Post by iamthwee » Sat Dec 23, 2006 2:26 am
Really nice work.
zsouthboy
Post by zsouthboy » Sat Dec 23, 2006 2:32 am
You even got the ribs on the wires perfect.
Awesome.
Post by OnoSendai » Sat Dec 23, 2006 2:36 am
I thought that was a normal smoothing problem, lol :)
rusted
Post by rusted » Sun Dec 24, 2006 4:46 am
great work-perfect! congrats!
garphik
Post by garphik » Sun Dec 24, 2006 7:11 am
great work Phil.
the render is very clean !
Pinko
Post by Pinko » Sun Dec 24, 2006 10:56 am
good work Phil!!! congrats!
Pinko. :wink:
Phil
Post by Phil » Tue Dec 26, 2006 11:24 pm
Thanks for your comments,
@zsouthboy
The ribs on the wire is a modeling problem, I just decide to let them so, because some imperfections gives more realism :lol:
@OnoSendai
Perhaps there is here a normal problem, but not on the wire, on the aluminium material.
I used here the sand blassed texture for the aluminium, but I never get the expected result.
I played with all parameter, nothing worked as expected.
After 1 or 2 hours the result looks good (for the aluminium) but after 1 day the interesting effect is gone :(
Perhaps Indigo just smooth too much in this case?
Noise should still be there in the aluminium material.
I am still investigating this point with other parameters, and so on :?
Thanks to all,
regards, Phil
Phil
Post by Phil » Thu Dec 28, 2006 12:56 am
Sorry, I excuse myself!
@OnoSendai
I forgott to copy the picture in the working directory :oops: :oops: :oops: :oops:
@moderator
can we delete this thread and the picture?
This was only a work in progress!
The next render will be much much better :D
Regards, Phil
Phil
Post by Phil » Sat Jan 13, 2007 9:38 am
This is the effect I wanted to obtain;
This should be be looks like a cast iron or something like that!
This was abaout 80 hours rendering time.
It is really hard to obtain a good results :wink:
I hope it will be bettter with 0,7
Regards, Phil
sprocket
Post by sprocket » Sat Jan 13, 2007 9:48 am
:shock: It's a photo right?
That's a super-nice material for the metal, is it a bumpmap?
awesomeness :D
Phil
Post by Phil » Sat Jan 13, 2007 9:07 pm
yes the material is a bump map, here is the code for information:
<material>
		<name>Alu_bumped</name>
		<phong>
			<nk_data>nkdata/Al.nk</nk_data>
			<exponent>900</exponent>
			<bump_map>
				<uv_set>uv</uv_set>
				<path>noisemi8.jpg</path>
				<gain>0.002</gain>
				<exponent>1.0</exponent>
			</bump_map>
		</phong>
	</material>
	<material>
		<name>alu_bumped.2</name>
		<phong>
			<exponent>700</exponent>
			<bump_map>
				<uv_set>uv</uv_set>
				<gain>0.003</gain>
			</bump_map>
		</phong>
	</material>
Regards, Phil
Users browsing this forum: No registered users and 123 guests
