I have been happily using Indigo 2.2.12 for quite some time now. I am running it on 3 Machines (lifetime license with 2 node licenses). Since my main workstation at work has only 2GB RAM I sometimes have to fire up the GUI on my Linux render slave (4GB RAM) and use the workstation as a slave. It seems that in this scenario - no matter what options I set in the GUI or igs file - I get the Indigo logo in the bottem right corner of every rendering. Is this intentional? I think for a paying customer this is quite a restriction. Any ideas on how I can solve this problem (other than adding RAM to my workstation)?
TIA for any input!
Indigo Logo being stubborn
Re: Indigo Logo being stubborn
Have you checked in your exporter to see if the logo is enabled?
You register your main Machine with the Master License! Only this machine can start renderings that don't have any (demo) restrictions like watermark & limited resolution!
Yup, it's not. It's like Zom-B said, only the machine with the master license can start renderings that lack the logo, however there sems to be no restriction on size.Godzilla wrote:Have you checked in your exporter to see if the logo is enabled?
I find that rather strange having to buy more main licenses to start renderings without any watermarks.
rendigo wrote:Yup, it's not. It's like Zom-B said, only the machine with the master license can start renderings that lack the logo, however there sems to be no restriction on size.Godzilla wrote:Have you checked in your exporter to see if the logo is enabled?
Perhaps you should put more than 2GB in your main workstation?
I wrote in my initial post other than adding RAM - this is my workstation @work and I don't want to drive 250 kilometers right now just to add RAMGodzilla wrote:rendigo wrote:Yup, it's not. It's like Zom-B said, only the machine with the master license can start renderings that lack the logo, however there sems to be no restriction on size.Godzilla wrote:Have you checked in your exporter to see if the logo is enabled?
Anyway, it's not that I don't know solutions for the problem, I wonder if this restriction to 1 main machine is necessary. A more flexible solution would be really nice.
You should have a full licence and 2 node licences. You can only have the full licence on one computer at a time. To access the power of your linux box, make sure it is using a node licence and then use network rendering
