Error trying to save rendered image
I've been having problems saving my rendered images. I keep getting an error saying that the image file is unsupported.
has anyone else had this problem?
Thanks for any help!
Re: Error trying to save rendered image
In the file name make sure there isn't any file extension (ie: .jpg) after it, and just choose something from the drop down like .PNG
If that doesn't work, could you post a screenshot? cheers
I didn't notice problem mentionen by EDS, there is some issue with saving though.
When i save render as f.e. 'scene.igi' and then try to save also 'scene.jpg' i got overwriting warning. It works only when i change one of the name to f.e. 'scene1' or change destination folder of one of above files. In other words there's no possibility to save two or more files with the same name and different extensions.
I use indigo 2.2.12 win32
Hi Soup,
I gave your suggestion a try, but it gave me the same error. I've attached an image to show you what it looks like.
- Indigo Error.jpg (239.43 KiB) Viewed 3974 times
There's a small bug in the gui that will be fixed shortly.wojtek-w wrote: When i save render as f.e. 'scene.igi' and then try to save also 'scene.jpg' i got overwriting warning. It works only when i change one of the name to f.e. 'scene1' or change destination folder of one of above files. In other words there's no possibility to save two or more files with the same name and different extensions.
See the attached image:
1. Saving as IGI
2. after saving as IGI the file extension remains, even if changing extension to .jpg
To fix this just delete the file extension and use the drop-down to select a new one.
As for EDS' problem, that is definitely weird. Try re-installing Indigo 2.2, but let us know if that doesn't work because the Indigo install should have all the image formats with it. What format are you trying to save as? jpg? png? etc
- saving.jpg (37.48 KiB) Viewed 3933 times
Hey EDS,
just had a talk with Ono, try to export your scene somewhere, and open up Indigo 'manually' (ie: start > programs > Indigo Renderer) and load the scene that way. That might work and let you save an image.
thx! Your tip to do it manually works, although in my case situation is a little bit diffrent.Soup wrote: To fix this just delete the file extension and use the drop-down to select a new one.
1. I enter file name without an extention in save dialog box and i chose igi from the drop down menu. file is saved as igi.
2. When i re-open save dialog box, the filename remains without extention and whateveer extention i chose from the dropdown menu program tries to save file as igi (or generaly with extension chosen previously). when i add manually extention to the file name everything works.
I mentioned that so you have correct data to fix this bug.
thx for your work. Indigo rocks anyway
edit: I've just realised that the bug may be exact as You said and I just can't see extention because of windows "hide known extention" option....
Hey Soup,
I found that the images were being saved automatically in the render folder of Indigo. I was able to get the most updated w/o having to go through the 'save file' button.
I will give ur suggestion a try next time. Or I will try to reinstall everything, sketchup & indigo.
Thanks for your suggestions!
Indigo makes a backup every so often, so it might not be quite the most recent. It's best to use the save image button, and it should work
