Doug Armand
by Doug Armand » Sat Jan 23, 2010 9:55 pm
Just a play on the dieting concept.
Thought I'd try and set it up as a fine food shot.
Not sure I'm co mpletely happy with the lighting but overall I think it's achieving the look I'm after
All modelling, lighting,etc by me
- default.jpg (107.32 KiB) Viewed 10079 times
Doug
Doug Armand
enricocerica
by enricocerica » Sat Jan 23, 2010 11:16 pm
I really like the idea, maybe some edge split on the kinife and the fork and someway bigger to well identify the pill.
Doug Armand
by Doug Armand » Sun Jan 24, 2010 2:22 am
OK updated it and this is probably the final version - fixed uneven lighting on fork and tweaked the sizes of some of the elements, the pill was big enough for a horse to take!
, and added 10mg text to pill ( which at this low res you can barely see).
Also flipped the knife as good table laying etiquette says the knife blade should be facing the plate
- default.jpg (81.63 KiB) Viewed 10002 times
Doug
Doug Armand
Meelis
by Meelis » Tue Jan 26, 2010 1:48 am
Nice lighting.
I like the 1st more contrasty version.
Where u inspired by the movie "Requiem For A Dream" (2000)
Doug Armand
by Doug Armand » Tue Jan 26, 2010 1:54 am
Meelis wrote:Nice lighting.
Thanks
No I haven't seen it but now thatr you've mentioned I'll check it out
Doug
Doug Armand
fenerolina
by fenerolina » Tue Jan 26, 2010 6:42 am
Doug Armand wrote:No I haven't seen it but now thatr you've mentioned I'll check it out
You have to see all darren aronofski films!
Polinalkrimizei
by Polinalkrimizei » Tue Jan 26, 2010 7:20 am
nice and quite unusual look for indigo output. Refreshing! But I also like the fist one better, the plate on the second one appears almost white on my screen.
Doug Armand
by Doug Armand » Tue Jan 26, 2010 3:19 pm
Polinalkrimizei wrote:nice and quite unusual look for indigo output. Refreshing! But I also like the fist one better, the plate on the second one appears almost white on my screen.
While I agree that the first one has better contrast I would suggest that if in the 2nd the plate looks almost white you should calibrate your screen?.
Check out here if your screen is calibrated:
http://home.comcast.net/~morrised2006/tips/monitor.htm
Doug
Doug Armand
Users browsing this forum: Baidu [Spider] and 36 guests
