Indigo 2.2 launches the material editor instead of renderin
giorgiomartini
Post by giorgiomartini » Wed Jan 20, 2010 11:44 am
Hi , i have installed the new version 2.2
im on mac i copied the tree icons that came to applicartions ( one icon was replaced , the older indigo icon )
i also installed the new blendigo 2.2
so when i press the render button i get the material editor not the actual renderer.
any ideas ?
remus
Re: Indigo 2.2 launches the material editor instead of renderin
Post by remus » Wed Jan 20, 2010 10:25 pm
right click the icon-> properties then change the path to: C:\Program Files\Indigo Renderer\indigo.exe
edit: sorry, missed the 'mac os x' bit :oops:
Post by zeitmeister » Thu Jan 21, 2010 1:00 am
giorgiomartini wrote:im on mac …
:mrgreen:
Serious: No problems here on OS X 10.5 + Indigo 2.2.12.
Maybe you could download it again?
giorgiomartini
Post by giorgiomartini » Thu Jan 21, 2010 1:54 am
download again ? :cry:
how could that help :? ?
anyway ill try when i get home , an other ideas ? :roll:
:D :D :D :D :D :D
Post by zeitmeister » Thu Jan 21, 2010 2:58 am
Ah, okay... then take a look at blendigo.
It should ask you of your default Indigo installation path; if it doesn't, try to remove blendigo, start blender, quit blender, install blendigo again and restart blender.
... that's how it works with Cindigo when having this issue... well, if. :mrgreen:
dougal2
Post by dougal2 » Thu Jan 21, 2010 3:37 am
zeitmeister wrote:It should ask you of your default Indigo installation path;
no, it doesn't. it should use the paths defined by the installer and stored in a file that Blendigo reads.
This is indeed a very odd issue - and I feel of limited use because I do not own a Mac that I can run Indigo on and I don't know how the executables are named or organized.
Ben ?
giorgiomartini
Post by giorgiomartini » Thu Jan 21, 2010 9:13 am
PLease ben help ;D
hope you can help me.
giorgiomartini
Post by giorgiomartini » Fri Jan 22, 2010 10:17 am
please , any mac user around ?
thanx !
dougal2
Post by dougal2 » Fri Jan 22, 2010 10:30 am
I'm trying currently to get my hands on a Mac. My most urgent task is to make Blendigo work properly on OSX.
Post by Headroom » Fri Jan 22, 2010 3:36 pm
Giorgio,
Not sure which version of Indigo you have installed on your mac. 2.2 stable is actually the same as 2.2.12. In the Blender section of the Forum dougal2 states that Blendigo 2.2 stable for MacOS is not out since it has problems, however for the other OS its equivalent to Blendigo 2.2.11-d, which BTW works flawlessly on my iMac. I had to correct the my path in the location file though to get it to work. Let me explain.
When you press the render button in Blendigo it uses a path to the Indigo executable stored in this file:
/Users/"your user name"/.indigo/location
In my case that file contains one line:
/Applications/Indigo.app
Check out what it contains in your case and correct if necessary. That should help, assuming that when you click on the Indigo application icon in the Applications directory in the Finder this really starts Indigo :wink:
Let us know if that works and if you need further assistance.
giorgiomartini
Post by giorgiomartini » Sat Jan 23, 2010 6:27 am
Hi ,
I have downloaded the installer that is right now in the downloads page , latest stable 2.2.12 for mac os.
NO , my indigo was installed ( by the installer ) in the applications folder :
Macintosh HD / Applications
So you say 2.2.12 is not ready for mac os , but , where is the 2.2 download i just can find it ?
Thanx !
dougal2
Post by dougal2 » Sat Jan 23, 2010 6:32 am
giorgiomartini wrote:So you say 2.2.12 is not ready for mac os , but , where is the 2.2 download i just can find it ?
You've answered your own question. There is no 2.2 stable release for Mac OSX because it doesn't work!
Please wait, I'm working on fixing it.
giorgiomartini
Post by giorgiomartini » Sat Jan 23, 2010 11:29 pm
thanx ,
so where can i find the one before 2.2 , that really works ?
thanx !
dougal2
Post by dougal2 » Sun Jan 24, 2010 12:02 am
To be honest, I'm not sure which of the previous versions worked and which didn't.
I've got access to OSX today, so hopefully I can get you something to test by the end of the day.
dougal2
Post by dougal2 » Sun Jan 24, 2010 5:13 am
Blendigo for OSX 2.2 Stable is now available. Please read the release post in the Blendigo forum before downloading!.
