tubes hot....
9 posts • Page 1 of 1
Kosmokrator
tubes hot....
Post by Kosmokrator » Thu Nov 23, 2006 3:45 am
ok i try to give some voltage to my tubes...here is the result...im not satisfied with this light....looks weird.....why? C&C please...
psor
Post by psor » Thu Nov 23, 2006 3:58 am
Heya Kosmo!
The tubes look better but mate, please not soooo lowpoly. Erm, ... and the
light, well what tonemapping do you use? ;o)
take care
psor
"The sleeper must awaken"
Kosmokrator
Post by Kosmokrator » Thu Nov 23, 2006 4:15 am
psor i know for the low poly..i fix later this just experiment with emmiters inside the tubes....i use standart tonemaping with d65...
i think there is nothing to do with tonemapping....i use rgb emmiter but why light goes in all the metal surface of tube?is like SSS effect...u understant what i mean? :roll:
psor
Post by psor » Thu Nov 23, 2006 4:24 am
Well, ... I would say your metal has a pretty low exponent and so the
reflection is NON-glossy and spreads the light over the surface ... :wink:
For the tonemapping I thought that you meant that the tubes are not bright
enough what could happen if you use reinhard tonemapping ...
take care
psor
Kosmokrator
Post by Kosmokrator » Thu Nov 23, 2006 4:30 am
ohhh......maybe u have right....then its normal and physical.....
ok i will try reinhard.....
thnx
Phil
Post by Phil » Tue Jan 16, 2007 8:16 am
Hi Kosmokrator,
I just wanted to wake up this thread! :wink:
Did you make some new tests with 0.7 :?:
Regards, Phil
Kosmokrator
Post by Kosmokrator » Tue Jan 16, 2007 8:27 am
no my friend no new 0.7 tests becouse no exporter for max and no free time...if found one of this...may i do something!
Phil
Post by Phil » Tue Jan 16, 2007 8:50 am
Jamas,
:( :( :( :( :( :cry:
Could you try it with a blender export perhaps :idea: :?:
Regards, Phil
Kosmokrator
Post by Kosmokrator » Tue Jan 16, 2007 8:54 am
i have no idea about blender...i know cinema maya and max but unfortynaly nothing about blender...i install it once and it s like before 15 years when i make my first steps in 3d...i have no time to learn a new 3d package at the moment..sorry.. :cry:
Users browsing this forum: No registered users and 76 guests
