Virtual Optics
5 posts • Page 1 of 1
Cyberdactyl
Virtual Optics
Post by Cyberdactyl » Thu Oct 01, 2009 1:59 am
Hi everyone,
I posted this at Sketchucation and thought it might be pertinent here. Also was wondering if anyone else has experimented with this ability of Indigo. . and I suppose, most any rendering engine.
After much experimentation with Indigo's material attributes, most especially, mirroring and glass, and the refraction index, for quite some time, I've managed to re-image an object entity in SU through a refractor-type optical system using Indigo. I used a modified Kellner-type eyepiece, more closely resembling a RKE. I used THIS site to help me develop some basic shapes and refractive indexes.
Here's the object I imaged and the optical setup in the distance. The distance ratio of the imaged object (the red slashed square) to the objective lens in relation to the objective and the 'eyepiece assembly plate' is 16 to 1.
Here's a view of the objective lens and the eyepiece assembly.
And the focusing or eyepiece assembly. I've changed the lenses to monochrome so they can be seen.
And finally the rendered image on the receiving plate.
The, newtonian-type system below was a bit harder because I needed to get the parabolic shape of the main mirror close to perfect. . .or as in the "the real world", get the wavelength error within several angstroms of, say, yellow light. A "real" telescope mirror has to be MUCH more accurate than what I am doing of course.
I've 'cheated' slightly here, in that I am not using eyepieces, and only letting the focus point of the image impact at the receiver plate. This would not allow a 'virtual eye' to see the image, as the image is crossing at the plate plane, and not traveling parallel. The imaged "SketchUp Indigo" was very close to the reflector. The ratio from the image to the receiver plate in comparison to the receiver plate to the top of the sagitta of the parabola is a modest 6 to 1, so I get a nice crisp image.
The below pic starts to show the error either in Indigo's ray tracing algorithm or the preciseness of my parabolic surface. I imagine it's my inability to draw an exact parabolic surface. The ratio here is a huge 320 to 1. Not much for a real optical system, but still kinda impressive in a virtual environment, not designed to do such.
remus
Re: Virtual Optics
Post by remus » Thu Oct 01, 2009 2:48 am
You could try turning subdivision smoothing on for your mirror material to make it smoother, not sure it would maintain the parabola shape though.
Cool tests by the way, tried something similar myself when i first started using indigo but was way out of my depth.
Meelis
Re: Virtual Optics
Post by Meelis » Thu Oct 01, 2009 8:11 am
That somewhat reminds to experiment withe some leica lense designs because they hawe cross-sections drawings, but im lazy.
http://us.leica-camera.com/assets/file/ ... e_3877.pdf
What was that really expencive glass on new 50mm f/0.95? :roll:
Re: Virtual Optics
Post by OnoSendai » Thu Oct 01, 2009 9:36 am
Cool!
Distortion artifacts in last image look like they're due to not enough triangles on parabolic lense.
Cyberdactyl
Re: Virtual Optics
Post by Cyberdactyl » Mon Oct 05, 2009 4:02 am
Thanks for the kind comments.
Meelis - I looked at that complex assembly and thought I'd give it a shot. I've yet to consider a complex camera lens.
I lifted the lens shapes as best I can, and started to look at the different variables I'm going to need to achieve an image. So far I can't seem to find a well focused combination. the 'engineering drawing' :roll: provided in the pdf hints at the distances of the movable sub-assemblies.
The complexity sky rockets with an eight lens assembly and it might be a bit too difficult as the pdf doesn't provide critical info such as refractive indexes. . .or coatings (not that coatings would be a big issue). It does provide performance charts, but back designing from that is about the same as reading ballistic tables of a gun and designing the mechanism and ammunition.
Users browsing this forum: No registered users and 70 guests
